Home » Modeling » EMF » [Teneo/Hibernate] eReference, containment, cascade all and deleting gone wrong
[Teneo/Hibernate] eReference, containment, cascade all and deleting gone wrong [message #783816] Thu, 26 January 2012 09:19 Go to next message
Hello everyone,
i am new to Teneo and got a problem which i could not solve on my own.
If i delete a Procedure object, the Variables don't get deleted, though
it's a containment reference.
I created a minimal example, hope one of you can see where things go wrong.
Thank you!
Relevant part of ecore model:
<eClassifiers xsi:type="ecore:EClass" name="Procedure">
<eStructuralFeature xsi:type="ecore:EReference"
name="variables" upperBound="-1"
eType="#//Variable" containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Variable">
<eStructuralFeatures xsi:type="ecore:EAttribute"
name="name" eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
Relevant options are set.
PersistenceOptions.CASCADE_POLICY_ON_CONTAINMENT, "ALL"
Part of annotations.xml:
<eclass name="Procedure">
<property name="variables">
<one-to-many mapped-by="Variable" indexed="false"/>
</property>
</eclass>
<eclass name="Variable">
</eclass>
Parts of source code:
Session session = sessionFactory.openSession();
Transaction tx = session.beginTransaction();
String hqlDelete = "delete Project.Procedure where name = :name ";
int deletedEntities = session.createQuery( hqlDelete ).setString(
"name", "procedure" ).executeUpdate();
tx.commit();
session.close();
Re: [Teneo/Hibernate] eReference, containment, cascade all and deleting gone wrong [message #783869 is a reply to message #783816] Thu, 26 January 2012 11:11 Go to previous messageGo to next message
Hi Matthias,
I guess it does not work because you use a delete query instead of going through the session. Another reason could be
that there is a join table for the one-to-many, so the join table records get deleted but not the child records.
Can you post the hbm? You can get it by calling dataStore.getMappingXML() after initializing it.
gr. Martin
On 01/26/2012 03:19 PM, Matthias Kloppenborg wrote:
> Hello everyone,
> If i delete a Procedure object, the Variables don't get deleted, though it's a containment reference.
> Thank you!
> </eClassifiers>
> </eClassifiers>
> </property>
> </eclass>
> </eclass>
> int deletedEntities = session.createQuery( hqlDelete ).setString( "name", "procedure" ).executeUpdate();
> tx.commit();
> session.close();
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo/Hibernate] eReference, containment, cascade all and deleting gone wrong [message #788789 is a reply to message #783869] Thu, 02 February 2012 03:13 Go to previous messageGo to next message
Hi Martin,
thanks for your help. I don't know why i didn't use the delete method of
the session. Now it works, thank you for your help.
Greetings
Matthias
P.S.: Can you give me a tip for good literature about teneo?
Am 26.01.2012 17:11, schrieb Martin Taal:
> Hi Matthias,
> through the session. Another reason could be that there is a join table
> child records.
> gr. Martin
>> Hello everyone,
>> wrong.
>> Thank you!
>> </eClassifiers>
>> </eClassifiers>
>> </property>
>> </eclass>
>> </eclass>
>> tx.commit();
>> session.close();
Re: [Teneo/Hibernate] eReference, containment, cascade all and deleting gone wrong [message #794746 is a reply to message #788789] Thu, 09 February 2012 11:53 Go to previous message
Hi Matthias,
Sorry I missed your ps, the wiki has extensive information:
http://wiki.eclipse.org/Teneo/Hibernate
gr. Martin
On 02/02/2012 09:13 AM, Matthias Kloppenborg wrote:
> Hi Martin,
> thanks for your help. I don't know why i didn't use the delete method of the session. Now it works, thank you for your
> help.
> Greetings
> Matthias
>> Hi Matthias,
>> child records.
>> gr. Martin
>>> Hello everyone,
>>> wrong.
>>> Thank you!
>>> </eClassifiers>
>>> </eClassifiers>
>>> </property>
>>> </eclass>
>>> </eclass>
>>> tx.commit();
>>> session.close();
The Netherlands
Previous Topic:Research Papers on CDO
Next Topic:Collaborative Modeling
Current Time: Sun Jul 20 08:34:06 EDT 2025
Powered by FUDForum. Page generated in 0.22488 seconds
