Home » Eclipse Projects » Eclipse Scout » Lookupservice (How to combine fixed sql with lookup)
Lookupservice [message #783235] Wed, 25 January 2012 05:30 Go to next message
I have a sql lookUpService like below that works fine
  public String getConfiguredSqlSelect() {
    return "SELECT bestandsnaam, bestandsnaam " +
        " FROM geluid " +
        " <key>where bestandsnaam = :key</key>  " +
        " <text>where upper(bestandsnaam) LIKE CONCAT(UPPER(:text), '%')</text>";
but now I want to combine this with some fixed SQL like "where obsolete = 0". Whatever I do I always get an SQL error.
So can I combine a fixed sql part with a lookup service and if yes, how should I do it.
Regards Bertin
Re: Lookupservice [message #783273 is a reply to message #783235] Wed, 25 January 2012 06:58 Go to previous messageGo to next message
Hi Bertin
You have to move your WHERE keyword out of the special tags.
        " FROM geluid " +
        " WHERE obsolete = 0 " +
        " <key>AND bestandsnaam = :key</key>  " +
        " <text>AND upper(bestandsnaam) LIKE CONCAT(UPPER(:text), '%')</text>";
Bruno
Re: Lookupservice [message #783292 is a reply to message #783273] Wed, 25 January 2012 07:44 Go to previous messageGo to next message
Works, thanks for the quick reply.
Regards Bertin
Re: Lookupservice [message #783366 is a reply to message #783292] Wed, 25 January 2012 10:39 Go to previous messageGo to next message
Is there a need to change or to clarify the documentation :
http://wiki.eclipse.org/Scout/Concepts/Sql_Lookup_Service
Re: Lookupservice [message #783385 is a reply to message #783366] Wed, 25 January 2012 11:14 Go to previous messageGo to next message
The documentation is too little, it does not tell everything, so a litlle more info would be welcome or some more complex examples.
I can change the documentation with whatever I know.
Re: Lookupservice [message #783391 is a reply to message #783385] Wed, 25 January 2012 11:25 Go to previous messageGo to next message
Indeed, we will update the documentation to clarify this - especially by providing some more examples.
Re: Lookupservice [message #783393 is a reply to message #783391] Wed, 25 January 2012 11:29 Go to previous message
I just noticed that the example I needed in the minicrm tutorial. But you only get there when you run through that example, not by looking at the concept pages.
Previous Topic:CalenderField
Next Topic:Server /process HTML page
Current Time: Sun Jul 20 10:31:20 EDT 2025
Powered by FUDForum. Page generated in 0.05261 seconds
