Home » Archived » BIRT » Item expand to page break
Item expand to page break [message #782821] Tue, 24 January 2012 09:16 Go to next message
I need to put an item A at the bottom of a page, so I thought at a item(grid) that cover the rest of tha page to put the item A at the bottom of it, but I can expand an item ad I described.
Re: Item expand to page break [message #782840 is a reply to message #782821] Tue, 24 January 2012 09:56 Go to previous messageGo to next message
Is the report in fixed layout (general report properties)? Did you set
the height of the grid rows?
Jason
Re: Item expand to page break [message #782923 is a reply to message #782840] Tue, 24 January 2012 13:32 Go to previous messageGo to next message
Fixed layout; I've tried setting the height of previous rows and with only one row, but without success
Re: Item expand to page break [message #783026 is a reply to message #782923] Tue, 24 January 2012 18:02 Go to previous messageGo to next message
Can you reproduce the issue with the sample db and post an example that
we can debug? What version of BIRT are you using?
Jason
Re: Item expand to page break [message #783176 is a reply to message #783026] Wed, 25 January 2012 03:26 Go to previous messageGo to next message
Jason Weathersby wrote on Tue, 24 January 2012 18:02
Jason
Yes, it's very simply.
A grid with two rows, the second row has yellow background.
I want to expand the yellow row height until the end of the page (so I can put the label at the bottom).
In this sample I'm using 3.7.1, but I have the same beaviour with other versions
Re: Item expand to page break [message #783362 is a reply to message #783176] Wed, 25 January 2012 10:30 Go to previous messageGo to next message
Take a look at the attached modified sample.
Jason
>> Jason
Re: Item expand to page break [message #783801 is a reply to message #783362] Thu, 26 January 2012 08:52 Go to previous messageGo to next message
It's not what I want because I don't know how many lines I have in the first row of the grid, so I don't know the height of the first row.
  • Attachment: sample2.zip
    (Size: 0.93KB, Downloaded 187 times)
Re: Item expand to page break [message #783887 is a reply to message #783801] Thu, 26 January 2012 11:56 Go to previous message
The only way I know to handle this is to use the page footer to display
the label.
Jason
Previous Topic:Custom Color/Gradient Palette definition through DE API
Next Topic:Reference Images on File System
Current Time: Sat Jul 19 12:03:31 EDT 2025
Powered by FUDForum. Page generated in 0.04295 seconds
