Home » Archived » M2M (model-to-model transformation) » [QVTO] Temporary objects, removing objects and current limitations ?
[QVTO] Temporary objects, removing objects and current limitations ? [message #78281] Fri, 04 April 2008 09:42 Go to next message
Originally posted by: yann.davin.gmail.com
Hi all,
I'm trying to build a little model merger with qvto.
I often want to create helpers that return a new model element without
adding it to the created transformed resource, but it seems that
when we use the 'object' function, the created element is automatically created inside
the resource, and it seems that is not possible to remove it.
When I try to set to null the reference to the created object,
it is moved at the top of the resource and not deleted from it.
So for the moment I've created Tuple which has a similar structure of the model element,
and I use it as return type of my helper, but it is not clean, and fastidious when the model is big,
I would like to know if there is better way at the current stage of the qvto implementation to create temporary model
elements, or to remove a element from the resource ?
example:
--simple model struct test
--Value
-- value : String
--Definition
-- name : Value
-- Is it possible to create objects without adding them to the created transformed resource ?
helper create():Value{
return object Value{value := 'test'}
-- created in the resource
--so i use tuple replacement
--helper create():Tuple(value : String) ...
-- Is it possible to remove a element from the resource ?
helper deleteName(inout d :Definition){
d.name := null; --elementA is moved to the top of the resource
Yann
Re: [QVTO] Temporary objects, removing objects and current limitations ? [message #78297 is a reply to message #78281] Fri, 04 April 2008 10:38 Go to previous messageGo to next message
Originally posted by: Alexander.Igdalov.borland.com
Hi Yann,
All the model objects created during a QVTO script execution must belong
to some model extent. These are defined in the transformation header,
for example:
transformation t(in a : ECORE, out b : ECORE, out fake : ECORE);
modeltype ECORE uses ecore('http://www.eclipse.org/emf/2002/Ecore');
Here 'a', 'b' and 'fake' are model extents used in the transformation.
Thus, creating model objects in nowhere is prohibited but you can a fake
out model extent and create your model element in it. To use your extent
you will probably need to explicitly refer to it. Use '@' symbol after
the type to do it, e.g.:
object ECORE::EPackage@fake {
name := 'runtime'
Note, that if you omit the extent reference:
object ECORE::EPackage {
name := 'runtime'
the QVT compiler will choose the first appropriate extent which is 'b'
in my sample.
HTH,
Alex.
yann davin wrote:
> Hi all,
> created inside
> the model element,
> qvto implementation to create temporary model elements, or to remove a
> example:
> --Value
> -- value : String
> --Definition
> -- name : Value
> Regards,
> Yann
Re: [QVTO] Temporary objects, removing objects and current limitations ? [message #78312 is a reply to message #78281] Fri, 04 April 2008 11:00 Go to previous message
Hi David,
Since M6 build - coming this Monday, you can use =
Model::removeElement(Element) operation.
Though, it's in CVS HEAD already.
transformation t(in a : ECORE, out b : ECORE);
main() {
var p:=3D object EPackage {};
b.removeElement(p); -- deletes p and performs cleanup of all references=
to it
Perhaps, it might be also useful to use Element::clone(), deepclone() if=
you wish to
copy certain parts of your modified model and make some custom changes. =
The copy will
be instantiated in the out extent so you will be resonsible for unwanted=
objects explicit
deletion as well.
There is a concept of intermediate classes in QVTo, which are not suppos=
ed =
to be part of the
transformation result. But in this case you define a new class, internal=
to the transf,
while in your case you deal with a known metamodel.
FYI, itermediate classes not implemented yet, but should be coming soon =
/Radek
On Fri, 04 Apr 2008 15:42:36 +0200, yann davin <yann.davin@gmail.com> =
wrote:
> Hi all,
> I often want to create helpers that return a new model element without=
> when we use the 'object' function, the created element is automaticall=
y =
> created inside
> So for the moment I've created Tuple which has a similar structure of =
> the model element,
> and I use it as return type of my helper, but it is not clean, and =
> I would like to know if there is better way at the current stage of th=
e =
> qvto implementation to create temporary model elements, or to remove a=
> example:
> --Value
> -- value : String
> --Definition
> -- name : Value
> -- Is it possible to create objects without adding them to the created=
> return object Value{value :=3D 'test'}
> d.name :=3D null; --elementA is moved to the top of the resource
> Regards,
> Yann
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Previous Topic:[QVTO] Adding custom operations for primitive data types
Next Topic:[ATL] Get model's name
Current Time: Sat Jul 19 15:01:58 EDT 2025
Powered by FUDForum. Page generated in 0.03628 seconds
