Home » Archived » BIRT » Date Format
Date Format [message #782880] Tue, 24 January 2012 11:30 Go to next message
I am new to BIRT. I have a report with a row that includes the following expression:
"ADDRESS: " + dataSetRow["ADDRESS"] + "; SSN: " + dataSetRow["SSN"] + "; COUNTY: " + dataSetRow["COUNTY"] + "; BIRTH DATE: " + dataSetRow["BIRTHDDATE"] + "; BIRTH PLACE: " + dataSetRow["BIRTHPLACE"]
The "BIRTHDDATE" field is formatted as yyyy-mm-dd. Can I change it to MM/dd/yy using <value-of format...>?
Re: Date Format [message #782969 is a reply to message #782880] Tue, 24 January 2012 15:58 Go to previous messageGo to next message
Yes, you can do it in this way :
<value-of format="MM/dd/yy">new Date()</value-of>
Re: Date Format [message #782996 is a reply to message #782880] Tue, 24 January 2012 16:59 Go to previous messageGo to next message
You can do this if the report item is a text element not a data item and
you set its type to html for example:
<VALUE-OF format="MMM-dd-yy hh:mm" >new Date();</VALUE-OF>
If you want to do this in a data item use the Formatter functions. See
this blog post:
http://birtworld.blogspot.com/2011/02/birt-formatting-numbers-and-dates.html
Jason
On 1/24/2012 11:30 AM, Michael Harless wrote:
> Hello,
> expression:
Re: Date Format [message #783032 is a reply to message #782969] Tue, 24 January 2012 18:24 Go to previous messageGo to next message
Sorry I did not see that you responded.
Re: Date Format [message #783465 is a reply to message #783032] Wed, 25 January 2012 14:09 Go to previous message
Thank you very much for your responses. I will give these a try.
Previous Topic:get dataSetRow value from client script
Next Topic:Hyperlinks created in xls file are invalid
Current Time: Sat Jul 19 19:18:34 EDT 2025
Powered by FUDForum. Page generated in 0.04092 seconds
