Home » Archived » BIRT » BIRT 3.7 Report with Multiple Columns(Trying to create a BIRT report with mutiple columns, but the feature doesn't appear to work.)
BIRT 3.7 Report with Multiple Columns [message #781578] Sat, 21 January 2012 12:45 Go to next message
Does BIRT 3.7 support multiple column reports. I've tried setting this up on the Master Page but no matter what I try the report is always rendered with a single column. I've read this should be supported now, but I've found no concrete examples or tutorials on how to make this work.
I am trying to set "Master Page" > "Advanced" > "Columns"
Re: BIRT 3.7 Report with Multiple Columns [message #782400 is a reply to message #781578] Mon, 23 January 2012 11:46 Go to previous messageGo to next message
Shane,
If you mean like a newspaper flow, it is not supported yet, but you can
just put a two or three column grid in and then put tables, charts, etc
into each of the columns. You can also add a computed column to tables
and filter the list of rows displayed in a table. Take a look at the
attached example.
Jason
Re: BIRT 3.7 Report with Multiple Columns [message #782897 is a reply to message #782400] Tue, 24 January 2012 12:00 Go to previous messageGo to next message
Thanks Jason. Yes, I am trying to have content flow into columns similar to a newspaper layout.
Do you know if it is on the roadmap at all? I can use computed columns and filters for some reports, but I can't think of a good way to have the report flow into columns the way I'd like.
Does the commercial product support this? I'm confused because there is information online that makes it seem like this feature has been implemented.
For example:
eclipse.org/birt/ref/rom/elements/GraphicMasterPage.html
Re: BIRT 3.7 Report with Multiple Columns [message #783035 is a reply to message #782897] Tue, 24 January 2012 18:28 Go to previous message
Shane
Currently this is not implemented in commercial or open source. It is
in bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=133218
Can you please vote on this?
Can you give some more detail on how you want it to flow and maybe with
some scripting we can provide a work around.
Jason
> implemented.
> For example:
> Thanks
Previous Topic:Localization of general Report Properties(Title, Description, Comments)
Next Topic:Integerating BIRT inside the Web Application
Current Time: Sat Jul 19 17:17:15 EDT 2025
Powered by FUDForum. Page generated in 0.04265 seconds
