Home » Archived » BIRT » creating javascript vector from dataSetRow(creating javascript vector from dataSetRow)
creating javascript vector from dataSetRow [message #781989] Sun, 22 January 2012 18:12 Go to next message
I just started using BIRT.
I'm wondering about an easy way to construct a javascript vector (or even a matrix) from dataSetRow elements.
I'd like to do some math on this vectors...
C
Re: creating javascript vector from dataSetRow [message #782407 is a reply to message #781989] Mon, 23 January 2012 11:55 Go to previous messageGo to next message
Do you want to do this in the server side script of BIRT or are you
wanting this to be a client side available array? If it is all server
side you can add a table tied to the dataset and load up a js array in
the table rows' oncreate or on the expression of a given item in the
table. Next you can hide the table with visibility so it does not show
in the report. Have a look at the attached example.
Jason
On 1/22/2012 6:12 PM, Christoph Kiehn wrote:
> Thanks C
  • Attachment: jsarray.zip
    (Size: 2.66KB, Downloaded 224 times)
Re: creating javascript vector from dataSetRow [message #782412 is a reply to message #781989] Mon, 23 January 2012 11:55 Go to previous messageGo to next message
Jason
> Thanks C
    (Size: 2.66KB, Downloaded 206 times)
Re: creating javascript vector from dataSetRow [message #782419 is a reply to message #781989] Mon, 23 January 2012 11:55 Go to previous messageGo to next message
Jason
> Thanks C
    (Size: 2.66KB, Downloaded 258 times)
Re: creating javascript vector from dataSetRow [message #782481 is a reply to message #782419] Mon, 23 January 2012 14:57 Go to previous messageGo to next message
Hi Jason,
thanks a lot!
This is just what I was looking for.
Greetings
C
Re: creating javascript vector from dataSetRow [message #783169 is a reply to message #782481] Wed, 25 January 2012 03:03 Go to previous message
Hi Jason,
thanks a lot!
Greetings
Ramon
Previous Topic:Integerating BIRT inside the Web Application
Next Topic:Set default value of a dynamic listbox parameter
Current Time: Sun Jul 20 19:21:08 EDT 2025
Powered by FUDForum. Page generated in 0.03959 seconds
