Home » Archived » BIRT » ROM UserProperty structure
ROM UserProperty structure [message #78135] Fri, 30 September 2005 09:53 Go to next message
This is a multipart message in MIME format.
--=_alternative 004C56528525708C_=
Content-Type: text/plain; charset="US-ASCII"
I plan to create an application that will generate report design template
files based on a base report template file. I want to mark these
generated report design template files with a version number and a type
id. Should I be using the UserProperty structure to mark the version
number and type id? Is there another mechanism I should use? Just want
some advice if this is the way to go.
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">I plan to create an application that
will generate report design template files based on a base report template
file. &nbsp;I want to mark these generated report design template files
with a version number and a type id. &nbsp;Should I be using the UserProperty
structure to mark the version number and type id? &nbsp;Is there another
mechanism I should use? &nbsp;Just want some advice if this is the way
to go.</font>
--=_alternative 004C56528525708C_=--
Re: ROM UserProperty structure [message #78213 is a reply to message #78135] Fri, 30 September 2005 15:09 Go to previous message
--------------38332C482F9EC48CC1FBB893
Content-Type: text/plain; charset=us-ascii
Yes userproperty could be used for your use case. Refer to
org.eclipse.birt.report.model.api.DesignElementHandle for all the
available methods to create and access user properties using DE API.
--Rima Kanguri.
> template files based on a base report template file. I want to mark
> these generated report design template files with a version number and
> a type id. Should I be using the UserProperty structure to mark the
> version number and type id? Is there another mechanism I should use?
> Just want some advice if this is the way to go.
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
<p>Yes userproperty could be used for your use case. Refer to org.eclipse.birt.report.model.api.DesignElementHandle
for all the available methods to create and access user properties using
DE API.
<p>--Rima Kanguri.
<br>&nbsp;
<p>sleeloy@ca.ibm.com wrote:
<blockquote TYPE=CITE>&nbsp;
<br><font face="sans-serif"><font size=-1>I plan to create an application
that will generate report design template files based on a base report
template file.&nbsp; I want to mark these generated report design template
files with a version number and a type id.&nbsp; Should I be using the
UserProperty structure to mark the version number and type id?&nbsp; Is
there another mechanism I should use?&nbsp; Just want some advice if this
is the way to go.</font></font></blockquote>
</html>
--------------38332C482F9EC48CC1FBB893--
Previous Topic:Getting a class instance from javascript.
Next Topic:Web Viewer of BIRT
Current Time: Sat Jul 19 16:00:41 EDT 2025
Powered by FUDForum. Page generated in 0.03019 seconds
