Home » Eclipse Projects » EGit / JGit » NPE on checkout
NPE on checkout [message #780813] Thu, 19 January 2012 08:46 Go to next message
After updating from the nightly build site today I now see the following NPE on checkout operations. The checkout itself works fine -- functionally nothing seems to be wrong.
An internal error occurred during: "Checking out branchx - refs/heads/master".
at java.io.File.<init>(File.java:305)
at org.eclipse.egit.ui.internal.branch.BranchProjectTracker.restore(BranchProjectTracker.java:236)
at org.eclipse.egit.ui.internal.branch.BranchProjectTracker.restore(BranchProjectTracker.java:219)
at org.eclipse.egit.ui.internal.branch.BranchOperationUI$1$2.postExecute(BranchOperationUI.java:194)
at org.eclipse.egit.core.op.BaseOperation.postExecute(BaseOperation.java:59)
at org.eclipse.egit.core.op.BranchOperation$1.run(BranchOperation.java:117)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2326)
at org.eclipse.egit.core.op.BranchOperation.execute(BranchOperation.java:123)
at org.eclipse.egit.ui.internal.branch.BranchOperationUI$1.run(BranchOperationUI.java:199)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
egit 1.3.0.201201181724
eclipse.buildId=M20110909-1335
java.version=1.6.0_29
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Re: NPE on checkout [message #780859 is a reply to message #780813] Thu, 19 January 2012 12:21 Go to previous messageGo to next message
Thanks for reporting this, this is a bug in the new code that tracks which projects are checked out on which branches.
I will push a fix for it soon.
Re: NPE on checkout [message #780861 is a reply to message #780813] Thu, 19 January 2012 12:29 Go to previous messageGo to next message
Pushed proposed fix to: http://egit.eclipse.org/r/#change,4973
Thanks again for reporting this.
Re: NPE on checkout [message #781109 is a reply to message #780861] Fri, 20 January 2012 09:53 Go to previous message
Fixed in this morning's update, thanks for the quick turnaround.
Previous Topic:Survey: key missing features
Next Topic:Compare with HEAD revision and .gitignore
Current Time: Sat Jul 19 09:33:09 EDT 2025
Powered by FUDForum. Page generated in 0.03293 seconds
