Home » Eclipse Projects » EclipseLink » show parameter values in sql log (no JPA)
show parameter values in sql log (no JPA) [message #780515] Wed, 18 January 2012 07:27 Go to next message
how can I go back to showing parameter values in sql instead of [x parameters bound]?
(See https://bugs.eclipse.org/bugs/show_bug.cgi?id=329852)
I found the answer for JPA
<property name="eclipselink.logging.parameters" value="true"/> in persistence.xml.
But I'm not using JPA. I have an oldfashioned ServerSession with a custom Log4j SessionLog. Where in java code should I set this property?
Thanx
Ana
Re: show parameter values in sql log (no JPA) [message #780537 is a reply to message #780515] Wed, 18 January 2012 09:11 Go to previous messageGo to next message
Hello Ana,
You will need to use SessionLog's setShouldDisplayData(Boolean) to change the value. If it has not been set though, parameters should print out if the log level is set to FINE or more.
Best Regards,
Chris
Re: show parameter values in sql log (no JPA) [message #780808 is a reply to message #780537] Thu, 19 January 2012 08:07 Go to previous message
Yes, that worked. Thank you.
Re: show parameter values in sql log (no JPA) [message #781000 is a reply to message #780537] Thu, 19 January 2012 08:07 Go to previous message
Re: show parameter values in sql log (no JPA) [message #781017 is a reply to message #780537] Thu, 19 January 2012 08:07 Go to previous message
Re: show parameter values in sql log (no JPA) [message #781034 is a reply to message #780537] Thu, 19 January 2012 08:07 Go to previous message
Previous Topic:Native ORM vs JPA
Next Topic:Native ORM vs JPA
Current Time: Sun Jul 20 14:57:28 EDT 2025
Powered by FUDForum. Page generated in 0.45923 seconds
