Home » Archived » BIRT » BIRT basics(Issue on charts)
BIRT basics [message #780466] Wed, 18 January 2012 02:22 Go to next message
I am new bee to BIRT.
Please provide links to have BIRT simple examples.
I am facing problems on creation of charts in my report.
Re: BIRT basics [message #780608 is a reply to message #780466] Wed, 18 January 2012 13:32 Go to previous messageGo to next message
Have you seen these:
http://www.eclipse.org/birt/phoenix/examples/reports/
They are a bit older but should be useful. Birt Exchange also has a lot
of example in the dev share.
Jason
On 1/18/2012 2:22 AM, Guru Prasad wrote:
Re: BIRT basics [message #786461 is a reply to message #780608] Mon, 30 January 2012 08:10 Go to previous messageGo to next message
I have written some java code to generate report using Birt libraries
package com.report.test;
import java.util.HashMap;
import java.util.logging.Level;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.HTMLRenderContext;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import org.eclipse.birt.report.engine.api.IRunTask;
public class RunTask {
public static void main( String[] args )
EngineConfig config = null;
IReportEngine engine = null;
IRunTask task = null;
//Open a report design
try{
config = new EngineConfig( );
//delete the following line if using BIRT 3.7 or later
config.setEngineHome( "C:/birt-runtime-3_7_1/birt-runtime-3_7_1/ReportEngine" );
config.setLogConfig("C:/birt-runtime-3_7_1", Level.FINE);
Platform.startup( config ); //If using RE API in Eclipse/RCP application this is not needed.
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject( IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );
engine.changeLogLevel( Level.WARNING );
IReportRunnable design = engine.openReportDesign("C:/birt-runtime-3_7_1/birt-runtime-3_7_1/ReportEngine/samples/hello_world.rptdesign");
//Create task to run the report - use the task to execute the report and save to disk.
task = engine.createRunTask(design);
//Set parent classloader for engine
//task.getAppContext().put(EngineConstants.APPCONTEXT_CLASSLOADER_KEY, RunTaskExample.class.getClassLoader());
//run the report and destroy the engine
task.run("C:/birt-runtime-3_7_1/birt-runtime-3_7_1/ReportEngine/samples/hello_world.rptdesign");
task.close();
engine.destroy();
Platform.shutdown();
}catch( Exception ex){
ex.printStackTrace();
if I run this ,
org.eclipse.birt.core.exception.BirtException: error.CannotStartupOSGIPlatform
at org.eclipse.birt.core.framework.Platform.startup(Platform.java:81)
at com.report.test.RunTask.main(RunTask.java:32)
Caused by: java.lang.SecurityException: class "org.eclipse.core.runtime.IAdapterManager"'s signer information does not match signer information of other classes in the same package
at java.lang.ClassLoader.checkCerts(Unknown Source)
at java.lang.ClassLoader.preDefineClass(Unknown Source)
at java.lang.ClassLoader.defineClassCond(Unknown Source)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$000(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at org.eclipse.birt.core.framework.jar.ServiceLauncher.startup(ServiceLauncher.java:45)
at org.eclipse.birt.core.framework.Platform.startup(Platform.java:75)
... 1 more
Please find attachment for libraries i'm using.
Re: BIRT basics [message #786663 is a reply to message #786461] Mon, 30 January 2012 12:28 Go to previous message
Do you have the birt runtime libs in your classpath/buildpath?
Remove this line:
Jason
> try{
> task.close();
> engine.destroy();
> if I run this ,
> at java.security.AccessController.doPrivileged(Native Method)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> ... 1 more
Previous Topic:Birt Client side scripting
Next Topic:Date Parameter
Current Time: Sat Jul 19 14:58:27 EDT 2025
Powered by FUDForum. Page generated in 0.05411 seconds
