Home » Eclipse Projects » EclipseLink » Metamodel not being created until after first use(Metamodel not being created until after first use)
Metamodel not being created until after first use [message #780453] Tue, 17 January 2012 21:54 Go to next message
I have this setup:
EclipseLink 2.3.2
Dali for generating metamodel classes
Spring 3.1 / Spring 3.1 MVC
Tomcat 7.0.20
Java 1.7
The problem is the first time i use my Metamodel, Account_.id, it is null. This is obviously not correct. Later calls to the same method the Account_.id correctly returns the SingularAttribute. From my understanding it is the responsibility of the JPA implementation to setup the metamodel. If I call persist first then find() I get a correct Account_.id.
Does anyone else have this problem or have seen this problem? It is pretty distinct, here is the stack trace:
at org.eclipse.persistence.internal.jpa.querydef.FromImpl.get(FromImpl.java:260)
at com.monstersoftwarellc.testApp.dao.AccountDAO.findAllOrderBy(AccountDAO.java:57)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:318)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:110)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at $Proxy19.findAllOrderBy(Unknown Source)
at com.monstersoftwarellc.virtualvote.HomeController.listUsers(HomeController.java:53)
at org.springframework.web.method.support.InvocableHandlerMethod.invoke(InvocableHandlerMethod.java:212)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:126)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:96)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:617)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:578)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:80)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:900)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:827)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:668)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:770)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:304)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:224)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:164)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:100)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:929)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:405)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:279)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:515)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:300)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:722)
Here you can see the next call works as expected :
Connection(1243367869)--Thread(Thread[tomcat-http--37,5,main])--SELECT ID, VERSION, LOGIN_ID, PERSON_ID FROM ACCOUNT ORDER BY ID ASC
Not sure what the problem is here, but can't have this in production. Any ideas or pointers?
Thanks!
Re: Metamodel not being created until after first use [message #780541 is a reply to message #780453] Wed, 18 January 2012 09:28 Go to previous messageGo to next message
Try the "eclipselink.deploy-on-startup" persistence property. This will help if the problem is that you are accessing the metamodel before the context is deployed, which without the property occurs on first access, not at startup.
Best Regards,
Chris
Re: Metamodel not being created until after first use [message #780559 is a reply to message #780541] Wed, 18 January 2012 10:59 Go to previous message
Hey Chris,
That worked like a charm!
Thanks for your help!
Re: Metamodel not being created until after first use [message #780996 is a reply to message #780541] Wed, 18 January 2012 10:59 Go to previous message
Hey Chris,
Re: Metamodel not being created until after first use [message #781013 is a reply to message #780541] Wed, 18 January 2012 10:59 Go to previous message
Hey Chris,
Re: Metamodel not being created until after first use [message #781030 is a reply to message #780541] Wed, 18 January 2012 10:59 Go to previous message
Hey Chris,
Previous Topic:Shared cache on multi base using same classes
Next Topic:Error generating static Data Objects from XSD
Current Time: Sun Jul 20 08:18:23 EDT 2025
Powered by FUDForum. Page generated in 0.03532 seconds
