Home » Archived » BIRT » XML URL - no authentication - no User/Password promt ?
XML URL - no authentication - no User/Password promt ? [message #778350] Thu, 12 January 2012 09:14 Go to next message
I have a strange problem with a BIRT Report. The report uses a XML DataSource URL from a web server which needs a user basic authentication.
In the past when I created such a new XML DataSource and click on the button 'Test Connection' eclipse prompted me with a username/password dialog. Also when I start my report with the menu action 'Run->view Report->in Web Viewer'.
But suddenly this is no longer working. Now I always got an HTTP Error 401 (Unauthorized response) and I got no chance to type in my username/password?
Did anybody know about that problem? I don't think that I have changed anything in my Eclipse or Server environment. And I have still designed different reports. So I know that this worked in the past.
Thanks for any help
Ralph
icon3.gif  Re: XML URL - no authentication - no User/Password promt ? [message #778396 is a reply to message #778350] Thu, 12 January 2012 13:27 Go to previous messageGo to next message
The problem was because I was running eclise in gnome shell. I solved the problem by providing a special start script.
See: http://www-02.imixs.com/roller/ralphsjavablog/entry/eclipse_and_gnome_shell
Re: XML URL - no authentication - no User/Password promt ? [message #778412 is a reply to message #778350] Thu, 12 January 2012 11:14 Go to previous messageGo to next message
The xml data source does not handle authentication (Unless you are using
custom code) so this must be coming from the browser?
Jason
On 1/12/2012 9:14 AM, Ralph Soika wrote:
> username/password?
> Thanks for any help
> Ralph
Re: XML URL - no authentication - no User/Password promt ? [message #778619 is a reply to message #778412] Fri, 13 January 2012 09:35 Go to previous messageGo to next message
Hi Jason,
thanks for your response. I have tested it on different clients. Normally when I create a new Data set with an xml url and press the button 'Test Connection' I got a login prompt from the Eclipse IDE.
But this prompt did not allways apear. This is really a strange behaivor and I can not found the reason why this is not working on some clients.
Re: XML URL - no authentication - no User/Password promt ? [message #779343 is a reply to message #778619] Sun, 15 January 2012 07:33 Go to previous messageGo to next message
Can you take a look at this posting:
http://www.eclipse.org/forums/index.php/t/276221/
It seems to me that egit is changing the extension point org.eclipse.equinox.security.loginModule which leads into this problem?
Ralph
Re: XML URL - no authentication - no User/Password promt ? [message #780378 is a reply to message #779343] Tue, 17 January 2012 12:28 Go to previous messageGo to next message
Ralph,
I am not certain but it sounds like you may be right.
Jason
> Ralph
Re: XML URL - no authentication - no User/Password promt ? [message #780408 is a reply to message #780378] Tue, 17 January 2012 13:35 Go to previous messageGo to next message
In the meantime I am absolutely sure that the EGit Plugin is responsible for that problem. Also my own Plugin (Imixs Workflow Modeler) is affected from the EGit behavior.
I am now activating/deactivating the Egit plugin several times a day Sad
Re: XML URL - no authentication - no User/Password promt ? [message #780410 is a reply to message #780378] Tue, 17 January 2012 13:35 Go to previous messageGo to next message
I am now activating/deactivating the Egit plugin several times a day :(
Re: XML URL - no authentication - no User/Password promt ? [message #780413 is a reply to message #780378] Tue, 17 January 2012 13:35 Go to previous messageGo to next message
Re: XML URL - no authentication - no User/Password promt ? [message #780416 is a reply to message #780410] Tue, 17 January 2012 13:44 Go to previous messageGo to next message
Have you logged a bug for this yet?
Jason
> affected from the EGit behavior. I am now activating/deactivating the
Re: XML URL - no authentication - no User/Password promt ? [message #780434 is a reply to message #780416] Tue, 17 January 2012 16:07 Go to previous messageGo to next message
Now I have created a bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=368882
Ralph
Re: XML URL - no authentication - no User/Password promt ? [message #780603 is a reply to message #780434] Wed, 18 January 2012 13:12 Go to previous message
Thanks for posting this.
Jason
> Ralph
Previous Topic:Report with RunningCount Throws NullPointerException
Next Topic:Data Source shows No Available Items
Current Time: Sun Jul 20 14:59:00 EDT 2025
Powered by FUDForum. Page generated in 0.87813 seconds
