Home » Modeling » TMF (Xtext) » DSL with "private" sections
DSL with "private" sections [message #779857] Mon, 16 January 2012 12:29 Go to next message
Hi all,
I am building a DSL where some objects must be hidden from outside a given scope. I.e., it should support something like "private" sections in C++ or private members in Java.
Simplified "toy" Smile example (left out import-stuff):
Model:
  (boxes+=Box)*
  (toys+=Toy)*
  (kids+=Kid)* ;
Box: 'box' name=ID (toys+=Toy)*;
Toy: 'toy' name=ID;
Kid: name=ID 'has' toy=[Toy|ID];
A kid should be able to reference only the toys which are part of Model.toys, not those which are in a box (Box.toys). In an extended version, each kid might have some access to more toys depending on the boxes' names.
After reading some documentation, I guess I have to provide my own implementation of IResourceDescription.Manager to avoid the "private" EObjects being published in the index. Additionally, I would have to add an additional filter (using local scoping) for handling intra-file references correctly.
However, this solution seems quite clumsy, there might be something more elegant. And: The above solution starts getting complicated in conjunction with FQN - how/where should the name computation for the exported EObjectDescription objects be done? So, I guess I went down the wrong path.
Did someone implement such "private"ish stuff before?
Thanks in advance and regards,
Klaus
Re: DSL with "private" sections [message #779892 is a reply to message #779857] Mon, 16 January 2012 13:54 Go to previous messageGo to next message
this basically works out of the box (with proper use of qualified names)
(in your case give model a name)
~Christian
Re: DSL with "private" sections [message #779905 is a reply to message #779892] Mon, 16 January 2012 14:40 Go to previous messageGo to next message
Hi Christian,
even after giving Model a name, it seems to me that the default behaviour with namespaces is that members of Box.toys can still be referenced. Where would the filtering be done which hides Box.toys members but keeps Model.toys members visible (note that Box.toys is just another Toy rule call, not a reference)?
Klaus
Re: DSL with "private" sections [message #779921 is a reply to message #779905] Mon, 16 January 2012 15:28 Go to previous messageGo to next message
i guess it is time for you to read something about scoping (google is your friend). there are lots of possibilities to solve such a problem.
~Christian
Re: DSL with "private" sections [message #780094 is a reply to message #779857] Tue, 17 January 2012 02:02 Go to previous messageGo to next message
Hi Klaus,
I'd allow to establish the cross reference but validate the visibility
explicitly. The error messages will be more helpful. You may want to
compare that approach with JDTs error messages if you try access
invisible members of a class.
Sebastian
Am 16.01.12 18:29, schrieb Klaus Birken:
> Hi all,
> Simplified "toy" :) example (left out import-stuff):
> Model:
> (boxes+=Box)*
> (toys+=Toy)*
> (kids+=Kid)* ;
> Toy: 'toy' name=ID;
> boxes' names.
> wrong path.
> Klaus
Re: DSL with "private" sections [message #780113 is a reply to message #780094] Tue, 17 January 2012 02:52 Go to previous message
Thanks Sebastian, this was a good hint - the implementation is quite easy this way and it will help the user of the DSL to understand the visibility rules.
Klaus
Previous Topic:cursor position in autocompletion using tabs
Next Topic:Simple Grammar causes Infinite Loop.
Current Time: Sat Jul 19 11:17:40 EDT 2025
Powered by FUDForum. Page generated in 0.04389 seconds
