Home » Eclipse Projects » GEF » ZEST: table cells as nodes / nodes in table cells?
icon5.gif  ZEST: table cells as nodes / nodes in table cells? [message #779759] Mon, 16 January 2012 08:46 Go to next message
Dear All,
I'm considering using ZEST for the first time for my RCP, and I have a general question: Is it possible to use the cells of a table as nodes?
Background: I want to draw a graph over a text which is placed in a a table. The table has one word per cell (all in one line), and I want to use the cells as nodes.
Alternatively, is it possible to place nodes in cells, and still "addres" them?
Many thanks!
[Updated on: Mon, 16 January 2012 08:47] by Moderator
Re: ZEST: table cells as nodes / nodes in table cells? [message #779765 is a reply to message #779759] Mon, 16 January 2012 09:06 Go to previous messageGo to next message
I think, it is not possible, or at least it is very hard to do. Zest uses an SWT Canvas to draw the Graph; while Table is a native widget in most operating systems. Some hack that would provide similar solutions is to put a Graph widget into every cell of the table, and then you have something you wanted.
However, it is possible to share data/selection between the Zest Graphs and your table. The simplest way to do this is using a JFace content provider for both the table (TableViewer) and the Zest Graph (in this case GraphViewer); and then you can synchronize the selection between the table and the graph nodes using a simple transformation code.
I hope, I could help a bit; or if not, please, clarify a bit your question.
Zoltán Ujhelyi
Re: ZEST: table cells as nodes / nodes in table cells? [message #780140 is a reply to message #779765] Tue, 17 January 2012 04:02 Go to previous messageGo to next message
Thanks Zoltán!
That helps indeed. I guess using a JFace content provider makes sense. One follow-up question, can nodes be styled to be "invisible"? That way I could put nodes over the individual cells and make it seem as if edges connect to cells, when they really connect to "invisible" nodes...
Re: ZEST: table cells as nodes / nodes in table cells? [message #813086 is a reply to message #780140] Sun, 04 March 2012 15:33 Go to previous message
Hi!
Sorry for the late answer - I hope its not too late.
It is possible to create invisible figures: you can modify your label provider to extend IFigureProvider (http://git.eclipse.org/c/gef/org.eclipse.zest.git/tree/org.eclipse.zest.jface/src/org/eclipse/zest/core/viewers/IFigureProvider.java - the same interface exists for Zest 1.x as well) to provide a custom Draw2D figure. Zest then draws the returned figure instead of the default implementation.
Zoltán Ujhelyi
Previous Topic:How to rotate draw2d label?
Next Topic:Connections selection after changing z-order of layers
Current Time: Sat Jul 19 10:47:55 EDT 2025
Powered by FUDForum. Page generated in 0.03767 seconds
