Drag & Drop table - dragging items down past window too slow [message #778250] |
Wed, 11 January 2012 18:39  |
I have a DND table, populated with a bunch of items and sometimes the list gets pretty long.
My problem is that when I try to drag an item down the list, once I get to the bottom of the window and it needs to start scrolling, it goes pretty slow. Since this list is sometimes quite long, I really need to be able to drag all the way down to the bottom much faster.
How would I accomplish this? Is there anyway to set the scroll speed depending on how long the list is?
I currently have this DND table wrapped in a ScrolledComposite, which did seem to help functionality a bit, but its still way to slow, and using ScrollBar and setting increment didn't seem to do anything either.
Any ideas?
Re: Drag & Drop table - dragging items down past window too slow [message #779981 is a reply to message #778747] |
Mon, 16 January 2012 18:50  |
In case anyone else finds this in search with the same problem, I'll write down the solution that I came up with.
What I did was wait for the DND table to enter the dragEnter method, at which point I used the getBounds() method of the table.
Then I grabbed all the parent containers outwards from the table and got their boundaries as well until I got to the SWT shell, and got its boundary as well.
Now that I have the exact boundary of the table in relation to the desktop, I just used the java.awt.MouseInfo class to get my current coordinates and whenever my mouse dragged to the top or bottom of the table, i would repeatadly update table.setSelection() incrementally until i got to the end of the list or the mouse moved away from the top or bottom of the table. (or release drag)
Works great.
FUDForum. Page generated in 0.03823 seconds
