Home » Eclipse Projects » EclipseLink » Query field created by the @OrderColumn
Query field created by the @OrderColumn [message #778453] Thu, 12 January 2012 05:26 Go to next message
I have an entity like this:
public class A {
@OneToMany
@OrderColumn(name = "ORDER")
private List<B> bList;
I need to fetch from database some B objects ordered by the created ORDER column.
If I define a field in B like this:
public class B {
@Column(name = "ORDER")
private Integer order;
EclipseLink try to create the "ORDER" column 2 times throwing an exception and doesn't create the B table.
I can't fetch A objects because I need to fetch some B objects belonging to different A objects (even no A objects)
How can I solve this?
Alessandro
Re: Query field created by the @OrderColumn [message #778622 is a reply to message #778453] Fri, 13 January 2012 09:43 Go to previous message
If you just want the list to be returned ordered, use the @OrderBy annotation instead. OrderColumn causes the field to be controlled by the collection.
Please file a bug though, as the field should not be written twice. Instead, you should get an exception stating that the field is mapped twice (since both the collection and the basic mapping try to write to the field).
Best Regards,
Chris
Previous Topic:Query field created by the @OrderColumn
Next Topic:set schema name for stored procedures using JPA
Current Time: Sun Jul 20 13:13:54 EDT 2025
Powered by FUDForum. Page generated in 0.02942 seconds
