Debug problem [message #777302] |
Tue, 10 January 2012 03:55  |
Hello all,
Is in LDT possible to debug script, which is located on remote machine with another OS?
I am trying to debug script with following configuration:
DBGP Server: Eclipse IDE 3.7.1 (x64), my PC with Win 7 (x64),
DBGP Client: remote linux machine (2.6.12)
When I tried to debug the script only on local machine, it works fine, but the remote debug failed, because the breakpoint was not catched.
I think that I have bad configurated the Source Mapping, but I don't know how can I map
the local file on my machine and remote file on Linux machine.
If you have had any ideas, please let me know.
Regards Josef G.
Re: Debug problem [message #781073 is a reply to message #780909] |
Fri, 20 January 2012 06:09  |
Hi Istvan,
If I understand it correctly, you have managed to perform a debug session when running the IDE and the script on the same machine, but didn't when trying from different machines?
Have you had a look at the "Source mapping" documentation http://wiki.eclipse.org/Koneki/LDT/User_Guide#DBGP_Server . It is important that the paths of the files mounted in your IDE are correctly mapped to the paths of the scripts you are running.
Let us know if you still have issues, there's certainly room for improvements in the documentation...
FUDForum. Page generated in 0.04278 seconds
