Home » Archived » M2M (model-to-model transformation) » Namespace Problems
Namespace Problems [message #777355] Tue, 10 January 2012 05:24
Hello Everyone.
I have a problem with namespace in my transformations. I am transforming one meta model into another using qvto. When transformed the namespace of my output file is something
<ABC xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://abc.org/schema/r4.0/abc40/atls" xmlns:_1="http://abc.org/schema/r4.0/abc40/swc/components" xmlns:_2="http://abc.org/schema/r4.0/abc40/swc/composition" xmlns:_3="http://abc.org/schema/r4.0/abc40/swc/composition/ir" xmlns:_4="http://abc.org/schema/r4.0/abc40/swc/pi" xsi:schemaLocation="http://abc.org/schema/r4.0/abc40/swc/composition/ir http://abc.org/schema/r4.0/abc40/swc/composition#//instancerefs">
where as the correct namespace is something like
<ABC xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://abc.org/schema/r4.0" xsi:schemaLocation="http://abc.org/schema/r4.0 abc_4-0-2.xsd">
First time when I run a configuration for transformation the transformed model is not valid. I understand it is because of the namespace. If I just copy and paste the correct namespace into the transformed file, save it and re run the configuration the transformed model is valid.
Can anyone please tell me what is happening here and how can I make my namespace correct for the first time so that I don't have to re run the configuration.
Ill appreciate your help.
Ahsan
Previous Topic:Plugin For Qvto Transformation
Next Topic:Migration of new profile definition does not work
Current Time: Sat Jul 19 19:38:08 EDT 2025
Powered by FUDForum. Page generated in 0.03492 seconds
