Home » Eclipse Projects » Rich Client Platform (RCP) » [re-opened] Order of mixed 'action' and 'command' menu items in RCP
[re-opened] Order of mixed 'action' and 'command' menu items in RCP [message #777348] Tue, 10 January 2012 05:11 Go to next message
At the moment I have two menus in my RCP application: File and Help.
The File menu is created via a command:
<extension point="org.eclipse.ui.menus">
  <menuContribution allPopups="false"
                    locationURI="menu:org.eclipse.ui.main.menu">
     <menu
           id="fileMenu"
           label="File"
           mnemonic="F"
           tooltip="Main Menu">
        <command
              commandId="myPlugin.bundle.menuCommands.Exit"
              label="Exit"
              mnemonic="E"
              style="push"
              tooltip="Exits MyPlugin">
        </command>
     </menu>
  </menuContribution>
  </extension>
<extension point="org.eclipse.ui.commands">
  <command defaultHandler="myPlugin.bundle.commands.exit.ExitHandler"
        id="myPlugin.bundle.menuCommands.Exit"
        name="Exit">
  </command>
</extension>
The Help menu (with only the About menu item) is created via the respective action in ApplicationActionBarAdvisor:
protected void makeActions(IWorkbenchWindow window) {
    aboutAction = ActionFactory.ABOUT.create(window);
    register(aboutAction);
protected void fillMenuBar(IMenuManager menuBar) {
    MenuManager helpMenu = new MenuManager("&Help", "helpMenu");
    helpMenu.add(aboutAction);
    menuBar.add(helpMenu);
Now, the Help menu comes before the File menu in the menu bar. This is obviously not how it's supposed to be. How can I change the order of the menus?
Many thanks!
[Updated on: Tue, 10 January 2012 06:45] by Moderator
Re: [solved] Order of mixed 'action' and 'command' menu items in RCP [message #777351 is a reply to message #777348] Tue, 10 January 2012 05:16 Go to previous messageGo to next message
Ah, solved this by simply adding a MenuManager in the ApplicationActionBarAdvisor for the File menu:
MenuManager fileMenu = new MenuManager("&File", "fileMenu");
    	menuBar.add(fileMenu);
D'uh! Smile
Re: [solved] Order of mixed 'action' and 'command' menu items in RCP [message #777387 is a reply to message #777351] Tue, 10 January 2012 06:46 Go to previous message
Hm, having second thoughts now. Is this really how it should be done? This would mean for every menu I create in the Extension Wizard, I have to put a new line of code in the ApplicationActionBarAdvisor...
Previous Topic:Help to draw different images in table according element data?
Next Topic:How do I get a menu item to refresh?
Current Time: Sun Jul 20 12:13:18 EDT 2025
Powered by FUDForum. Page generated in 0.06619 seconds
