Home » Modeling » TMF (Xtext) » XBase model inferrer problem
XBase model inferrer problem [message #773541] Sun, 01 January 2012 18:35 Go to next message
I tried to use the XBase model inferrer on my DSL as described in the documentation. Until a specific point it worked as expected (classes/methods were generated, they were navigable, etc.), but then I changed something, and after that point no classes were generated.
Sadly, no exception (checked with an exception breakpoint as well), error message (neither in console nor in the problems view) or any indication is provided what happens under the hood, just the output is missing. I tried debugging my code, the inferrer gets invoked, the JVMGenericTypes are created, and as far I understood the model, it seemed correct as well.
I tried to go back to a version from the history that I remembered correct, but it does not works now; however, when I use the domain model example on the same project, code generation works as expected (the Xtext builder was set).
I am sure that I misconfigured something really trivial, but I cannot find it. However, I would be really grateful, if you could give me a hint, what workflow fragment or Guice binding override could case such issues, or at least where to setup some breakpoints to observe what might be the problem.
Thank you for your help in advance,
Zoltan Ujhelyi
Re: XBase model inferrer problem [message #773786 is a reply to message #773541] Mon, 02 January 2012 09:31 Go to previous messageGo to next message
XtextBuilder.doBuild(ToBeBuilt, IProgressMonitor, BuildType) would be a
helpful breakpoint. Maybe you changed validation? Note that erroneous
resources are excluded from the build.
Am 02.01.12 00:35, schrieb Zoltan Ujhelyi:
> Zoltan Ujhelyi
Re: XBase model inferrer problem [message #773791 is a reply to message #773786] Mon, 02 January 2012 09:53 Go to previous messageGo to next message
Thank you for your quick help. After some sleep I already found the same builder class to start, so just now I finally found the problem. Although the builder fragment was added to the workflow, the builder was missing from the plugin.xml. After copying the relevant changes from plugin.xml_gen, it works.
And I started hacking because of validation, as I ran into the same issue as Lorenzo Bettini in http://www.eclipse.org/forums/index.php/t/262760/
Thank you again,
Zoltan
Re: XBase model inferrer problem [message #773849 is a reply to message #773791] Mon, 02 January 2012 12:51 Go to previous messageGo to next message
and did you solve it? :)
cheers
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: XBase model inferrer problem [message #773890 is a reply to message #773849] Mon, 02 January 2012 15:30 Go to previous message
Sadly, no.
After some minor experimentation with using a custom qualified name provider (it did not work) I searched for the problem, and found your thread and the bugzilla entry, and for now simply turned off validation. It was much more pressing, that the code generation did not work afterwards some other changes in the workflow file... Very Happy
Zoltán
Previous Topic:JvmTypeReference and JvmGenericType
Next Topic:Error MWE2 Workflow Generator
Current Time: Sat Jul 19 08:36:25 EDT 2025
Powered by FUDForum. Page generated in 0.08768 seconds
