Home » Modeling » TMF (Xtext) » validation invocation from the generator.Main
Re: validation invocation from the generator.Main [message #772754 is a reply to message #772744] |
Fri, 30 December 2011 08:50   |
On 12/30/2011 02:34 PM, Lorenzo Bettini wrote:
> On 12/30/2011 12:41 PM, Christian Dietrich wrote:
>> P.s: with abstract xtext tests e.g. only one test method will work.
>> two will not.
> Christian, I feel so stupid: I was running the test with a valid input
> file, instead of the input file with errors... :)
> so the problem is not there anymore... though I don't understand your
> current answer...
probably it's related to this: on another junit test, instead of using
AbstractXtextTests I'm using this class
@SuppressWarnings("all")
@InjectWith(XtypesInjectorProvider.class)
@RunWith(XtextRunner.class)
public class GeneratedJavaCodeTest ...
and I noted that by running a single test method my Java validator is
used, while running all test methods my Java validator is not used... I
don't have any setup method here...
is it related to what you said?
thanks in advance
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Current Time: Sun Jul 20 15:03:38 EDT 2025
Powered by FUDForum. Page generated in 0.07076 seconds
