Home » Modeling » TMF (Xtext) » validation invocation from the generator.Main
validation invocation from the generator.Main [message #772646] Fri, 30 December 2011 04:20 Go to next message
the generated Main class for invoking the generator of the DSL uses
@Inject
private IResourceValidator validator;
and calls validation as follows
// validate the resource
List<Issue> issues = validator.validate(resource, CheckMode.ALL,
CancelIndicator.NullImpl);
however, this will not use validation performed by the declarative
DSLJavaValidator
is that intentional?
cheers
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: validation invocation from the generator.Main [message #772650 is a reply to message #772646] Fri, 30 December 2011 04:40 Go to previous messageGo to next message
Hi Lorenzo,
i cannot reproduce this one.
~Christian
Re: validation invocation from the generator.Main [message #772655 is a reply to message #772650] Fri, 30 December 2011 04:53 Go to previous messageGo to next message
On 12/30/2011 10:40 AM, Christian Dietrich wrote:
> Hi Lorenzo,
> ~Christian
Christian
do you mean that also the Java validator is invoked in your case?
cheers
Lorenzo
Re: validation invocation from the generator.Main [message #772657 is a reply to message #772655] Fri, 30 December 2011 05:02 Go to previous messageGo to next message
Jepp
here is what i get for the domain model example
WARNING:Name should start with a capital (test.mydsl line : 1)
~Christian
Re: validation invocation from the generator.Main [message #772668 is a reply to message #772657] Fri, 30 December 2011 05:22 Go to previous messageGo to next message
On 12/30/2011 11:02 AM, Christian Dietrich wrote:
> Jepp
> ~Christian
then probably something is wrong in Junit tests (I'm experiencing this
problem in Junit tests): I do
protected void setUp() throws Exception {
super.setUp();
with(MyDslStandaloneSetup.class);
generator = get(Main.class);
but probably in Junit tests the Java validator is not registred
explicitly, is it? That's why for testing validators in Junit test we
must use ValidatorTester?
cheers
Lorenzo
Re: validation invocation from the generator.Main [message #772672 is a reply to message #772668] Fri, 30 December 2011 05:34 Go to previous messageGo to next message
no this works good as well.
public class DummyTest extends AbstractXtextTests {
	private Main generator;
	super.setUp();
	@Test
	public void testIt() {
		generator.runGenerator("test.mydsl");
but be careful, sometimes you destroy emf registries (e.g. the one for the validator)
accitentially in your tests. there where some bugs arround this too.
can you share a complete test case?
~Christian
Re: validation invocation from the generator.Main [message #772698 is a reply to message #772672] Fri, 30 December 2011 06:27 Go to previous messageGo to next message
On 12/30/2011 11:34 AM, Christian Dietrich wrote:
> @Override
> super.setUp();
> @Test
> the validator)
I'll try to provide enough information: I have a base class for tests
public class XtypesAbstractTests extends AbstractXtextTests {
super.setUp();
with(XtypesStandaloneSetup.class);
and then I have
public class XtypesGeneratorRunnerTests extends XtypesAbstractTests {
Main generator;
static {
System.setProperty("line.separator", "\n");
super.setUp();
generator.setOutputPath(null);
Do you think it's the derived class which might destroy something?
thanks in advance
Lorenzo
Re: validation invocation from the generator.Main [message #772703 is a reply to message #772698] Fri, 30 December 2011 06:39 Go to previous messageGo to next message
Nope,
this works as well. so can you share a complete test scenario that fails with the Greeting example.
a hint: try to debug the validation / the registry - is
there a point there stuff is removed from the registries?
~Christian
Re: validation invocation from the generator.Main [message #772704 is a reply to message #772703] Fri, 30 December 2011 06:41 Go to previous messageGo to next message
P.s: with abstract xtext tests e.g. only one test method will work.
two will not.
Re: validation invocation from the generator.Main [message #772705 is a reply to message #772704] Fri, 30 December 2011 06:42 Go to previous messageGo to next message
PPs: when working on the same model
Re: validation invocation from the generator.Main [message #772744 is a reply to message #772704] Fri, 30 December 2011 08:34 Go to previous messageGo to next message
> two will not.
Christian, I feel so stupid: I was running the test with a valid input
file, instead of the input file with errors... :)
so the problem is not there anymore... though I don't understand your
current answer...
cheers
Lorenzo
Re: validation invocation from the generator.Main [message #772754 is a reply to message #772744] Fri, 30 December 2011 08:50 Go to previous messageGo to next message
>> two will not.
> current answer...
probably it's related to this: on another junit test, instead of using
AbstractXtextTests I'm using this class
@SuppressWarnings("all")
@InjectWith(XtypesInjectorProvider.class)
@RunWith(XtextRunner.class)
public class GeneratedJavaCodeTest ...
and I noted that by running a single test method my Java validator is
used, while running all test methods my Java validator is not used... I
don't have any setup method here...
is it related to what you said?
thanks in advance
Lorenzo
Re: validation invocation from the generator.Main [message #772809 is a reply to message #772754] Fri, 30 December 2011 11:45 Go to previous messageGo to next message
Yes,
would be nice if you file a ticket
~Christian
Re: validation invocation from the generator.Main [message #773100 is a reply to message #772809] Sat, 31 December 2011 08:38 Go to previous messageGo to next message
On 12/30/2011 05:45 PM, Christian Dietrich wrote:
> Yes,
> ~Christian
I will, but I noted this behavior only with this usage
while you were referring to AbstractXtextTests too?
cheers
Lorenzo
Re: validation invocation from the generator.Main [message #773102 is a reply to message #772809] Sat, 31 December 2011 08:44 Go to previous message
> Yes,
> ~Christian
here it is
https://bugs.eclipse.org/bugs/show_bug.cgi?id=367679
cheers
Lore
Previous Topic:arbitrary returns
Next Topic:How to generate annotations like @Table(name="MY_TABLE")
Current Time: Sun Jul 20 07:48:54 EDT 2025
Powered by FUDForum. Page generated in 0.04954 seconds
