Window Builder has changed [message #770341] |
Fri, 23 December 2011 19:32  |
hi all,
Im probably the newest noob on the block just starting out with eclipse Gallilao3.5 Java and Android so excuse the, probably, simplistic issue here.
I started to build a practice GUI with the WebBuilder plug-in & really like it; that was 4-5 months ago - However since then i installed the Google Web Toolkit plugin and then returning to my WebBuilder Application i notice webBuilder has now become The
GWT Designer 1.2.0.rxxxxx??
Most noticeable is a jumpy, very slow sluggish interface when building (as if online with a slow connection). Can i get back to WebBuilder - i just want to build a desktop app in WebBuilder/Java saved as a .jar file - no web interactivity is required.
I already use google tools for online stuff hence installing GWT - but i dont want it to replace WindowBuilder which i was really enjoying learning.
any suggestions please.
Many thanks.
p.s. i use Windows Vista Home 32bit - i did read about the "flickering" issue in Linux but don't really understand if its the same issue.
FUDForum. Page generated in 0.05878 seconds
