Home » Modeling » TMF (Xtext) » Combining importURI and importedNamespace
Combining importURI and importedNamespace [message #769566] Thu, 22 December 2011 05:47 Go to next message
Hi there,
my Editor should hande two file-types.
The one with the extension .os declares a namespace like this:
using Main.C;
using Main.B;
using Main2.*;
#include "relativePath/morepath/anoNasp.osi"
namespace Main {
    B newFunctionDeclaration(C parameter) {
        ... Statements ...
        parameter = otherFunctionDeclaration(this);
        ... Statements ...
The imported namespaces have the same form.
The UsingImport rule look in the grammar:
UsingImport : 'using' importedNamespace=QualifiedNameWithWildCard ';';
The Include rule:
Include : '#include' importURI=STRING;
The included files have the file extension osi and only can declare anonymous namespaces like this:
namespace {
    C otherFunctionDeclaration(Main parameter) {
        ... Statements ...
My workflow contains the following lines:
// scoping and exporting API
fragment = scoping.ImportURIScopingFragment {}
// fragment = exporting.SimpleNamesFragment {}
fragment = scoping.ImportNamespacesScopingFragment {}
fragment = exporting.QualifiedNamesFragment {}
My question is: Which ScopeProviders I have to use to make this work?
How can I combine the two ImportUriGlobalScope and ImportedNamespaceAwareLocalScope?
Which Providers (e.g. NameProviders) I also have to individualize?
I've also written an ImportUriResolver, so the included recources can be found.
But if I call any Scope in my own OSScopeProvider or OSLinkingService, they are very empty. Why?
I know, anything should work out-of-the-box, but I don't know the right key for the box Wink
Re: Combining importURI and importedNamespace [message #769589 is a reply to message #769566] Thu, 22 December 2011 06:37 Go to previous messageGo to next message
Oh, I forgot:
I have no possibility to change the syntax of this grammar. Only the semantics.
Thank you for your replies, in advance.
Torsten
Re: Combining importURI and importedNamespace [message #769649 is a reply to message #769589] Thu, 22 December 2011 08:23 Go to previous messageGo to next message
An interesting phenomenon:
If I deactivate the binding to the ImportUriGlobalScope, the imported namespaces are in the scope of a Resource plus all objects of all anonymous namespaces.
If I activate the binding to the ImportUriGlobalScope, all objects of the included anonymous namespaces are in the scope but no imported namespaces accept of the own.
Re: Combining importURI and importedNamespace [message #769671 is a reply to message #769649] Thu, 22 December 2011 09:03 Go to previous messageGo to next message
without knowledge of your metamodel(s) - is it one is it two ....
it is hard to answer such a question. so two reproducable grammars would help.
never the less have a look how global scopeproviders are used:
org.eclipse.xtext.scoping.impl.AbstractGlobalScopeDelegatingScopeProvider.getGlobalScope(Resource, EReference, Predicate<IEObjectDescription>)
maybe you should delegate here to one of both global scopeproviders
depending of the type of the ereference.
(or you combine both and take care that stuff from the imported files is not in the index)
~Christian
[Updated on: Thu, 22 December 2011 09:19] by Moderator
Re: Combining importURI and importedNamespace [message #769681 is a reply to message #769671] Thu, 22 December 2011 09:27 Go to previous messageGo to next message
Thank you,
this is the Beginning of my Skript
Skript :
  imports+=UsingImport* includes+=Include* annotations+=Annotation* (namespace=Namespace | anonymousNamespace=AnonymousNamespace);
// Imports other namespaces
// Namespace identifier with wild card
QualifiedNameWithWildCard: QualifiedName '.*'?;
// Includes whole Files defined in importURI
// An unnamed namespace: defines functions for a related namespace
AnonymousNamespace : {AnonymousNamespace}
	'namespace'
	'{' (functionDeclarations+=FunctionDeclaration | textDefinitions+=TextDefinition)* '}';
// A namespace or extension definition
// Has boolean attribute isExtension
Namespace:
	('namespace'|extension?='extension')
	name = QualifiedName
FunctionDeclaration :
  returnType=[Namespace|QualifiedName] name=ShortIdentifier
  '(' (paramDefs+=VariableDeclaration (',' paramDefs+=VariableDeclaration)*)? ')'
  statement=Statement;
Statement :
...    (varDef=VariableDeclaration (assignmentWithDeclaration?='=' expression=Expression)? varDecl?=';') ...;
Expression:
... functionName=[FunctionDeclaration|QualifiedName] '(' (expressions+=Expression (',' expressions+=Expression)*)? ')' ... ;
The Reference to FunctionDeclaration can be a imported function referenced by a QualifiedName or a local / included function referenced by a ID.
So unfortunately the type of the Reference is the same.
Re: Combining importURI and importedNamespace [message #769691 is a reply to message #769681] Thu, 22 December 2011 09:39 Go to previous messageGo to next message
How can I combine two globalScopeProviders? And which is the one for Importing Namespaces?
Re: Combining importURI and importedNamespace [message #769692 is a reply to message #769691] Thu, 22 December 2011 09:40 Go to previous messageGo to next message
this is one grammar where is the second one?
~Christian
Re: Combining importURI and importedNamespace [message #769693 is a reply to message #769692] Thu, 22 December 2011 09:41 Go to previous messageGo to next message
P.s: use DefaultGlobalScopeProvider for "namespace" behaviour
Re: Combining importURI and importedNamespace [message #769697 is a reply to message #769693] Thu, 22 December 2011 09:51 Go to previous messageGo to next message
Two grammars? What do you mean? I only have one for my Editor.
Re: Combining importURI and importedNamespace [message #769701 is a reply to message #769697] Thu, 22 December 2011 09:58 Go to previous messageGo to next message
this is an important fact you didnt mention before.
~Christian
Re: Combining importURI and importedNamespace [message #769708 is a reply to message #769701] Thu, 22 December 2011 10:10 Go to previous messageGo to next message
Oh, I'm sorry.
Ok now I've tried the following:
public class OSImportUriGlobalScopeProvider extends ImportUriGlobalScopeProvider {
    @Inject
    DefaultGlobalScopeProvider provider;
    //Is bound in the RuntimeModule
    public IScope getScope(final Resource resource, final EReference reference,
        final Predicate < IEObjectDescription > filter) {
        final IScope scope = this.provider.getScope(resource, reference, filter);
        return getScope(scope, resource, isIgnoreCase(reference), reference.getEReferenceType(), filter);
    protected IScope getScope(final IScope parent, final Resource resource, final boolean ignoreCase,
        final EClass type, final Predicate < IEObjectDescription > filter) {
        final LinkedHashSet < URI > uniqueImportURIs = getImportedUris(resource);
        final IResourceDescriptions descriptions = getResourceDescriptions(resource, uniqueImportURIs);
        final List < URI > urisAsList = Lists.newArrayList(uniqueImportURIs);
        Collections.reverse(urisAsList);
        IScope scope = parent;
        for (final URI uri : urisAsList) {
            scope = createLazyResourceScope(scope, uri, descriptions, type, filter, ignoreCase);
        return scope;
and it works.
But the scope contains all objects of the anonymousNamespaces.
So it's the same result like I would get without using the ImportUriGlobalScope.
Re: Combining importURI and importedNamespace [message #769717 is a reply to message #769708] Thu, 22 December 2011 10:30 Go to previous messageGo to next message
if you store the anon stuff to the index it is in the index.
so this is what could work
(quick and dirty try with your grammar)
public class StrangeResourceDescriptionStrategy extends
		DefaultResourceDescriptionStrategy {
	private final static Logger LOG = Logger.getLogger(StrangeResourceDescriptionStrategy.class);
	public boolean createEObjectDescriptions(EObject eObject, IAcceptor<IEObjectDescription> acceptor) {
		if (getQualifiedNameProvider() == null)
			return false;
		try {
			QualifiedName qualifiedName = getQualifiedNameProvider().getFullyQualifiedName(eObject);
			if (qualifiedName != null) {
				Map<String, String> userData = new HashMap<String, String>();
				if (EcoreUtil2.getContainerOfType(eObject, AnonymousNamespace.class)!=null) {
					userData.put("anon", Boolean.TRUE.toString());
				IEObjectDescription create = EObjectDescription.create(qualifiedName, eObject, userData);
				acceptor.accept(create);
		} catch (Exception exc) {
			LOG.error(exc.getMessage());
		return true;
    @Inject
    	Predicate<IEObjectDescription> filter2 =new Predicate<IEObjectDescription>() {
			public boolean apply(IEObjectDescription d) {
				return ! Boolean.TRUE.toString().equals(d.getUserData("anon"));
        final IScope scope = this.provider.getScope(resource, reference, filter != null ? Predicates.and(filter, filter2) : filter2);
        return scope;
Re: Combining importURI and importedNamespace [message #769730 is a reply to message #769717] Thu, 22 December 2011 10:49 Go to previous message
It works like magic!
Thanks a million, Christian! Smile
Previous Topic:Type Inference with XBase
Next Topic:Debugging model post processing
Current Time: Sun Jul 20 17:14:19 EDT 2025
Powered by FUDForum. Page generated in 0.04455 seconds
