Getting Undone proposal applications (from quick fix) using IOperationHistoryListener [message #769007] |
Wed, 21 December 2011 03:33 |
Hi all,
I am using IOperationHistoryListener as follows:
public class ObservationOperationHistoryListener implements IOperationHistoryListener
public void historyNotification(OperationHistoryEvent event)
IUndoableOperation op = event.getOperation();
if (op instanceof TriggeredOperations)
op = ((TriggeredOperations) op).getTriggeringOperation();
UndoableOperation2ChangeAdapter changeOperation = null;
if (op instanceof UndoableOperation2ChangeAdapter)
changeOperation = (UndoableOperation2ChangeAdapter) op;
if (changeOperation == null)
return;
Change change = changeOperation.getChange();
if (change == null)
return;
String changeName = change.getName();
switch (event.getEventType())
case OperationHistoryEvent.ABOUT_TO_EXECUTE:
break;
case OperationHistoryEvent.ABOUT_TO_UNDO:
break;
case OperationHistoryEvent.ABOUT_TO_REDO:
break;
case OperationHistoryEvent.DONE:
break;
case OperationHistoryEvent.UNDONE:
//Proposal undone detected. Do something with the change.
break;
case OperationHistoryEvent.REDONE:
break;
case OperationHistoryEvent.OPERATION_NOT_OK:
break;
case OperationHistoryEvent.OPERATION_ADDED:
break;
case OperationHistoryEvent.OPERATION_REMOVED:
break;
I have a problem with the following:
Consider the following two scenarios:
1-) The user invokes quick fix, selects a proposal, invokes another quick fix, selects a proposal, undoes (ctrl+z), undoes.
In this case, I can successfully get all undo events as proposal undo events (with the above code)
2-) The user invokes a quick fix, selects a proposal, invokes another quick fix, select a proposal, puts a whitespace somewhere, undoes (white space), undoes (second proposal application), undoes (first proposal application).
In this case, all undo events are degraded down to basic typing events and I cannot detect the last two undoes (with the above code). Basically the whitespace at the end breaks everything!
My question: Why does the event type for the first two proposal applications change when the user adds a whitespace at the end? am I getting something wrong?
Second question: Is there a better (or easier) way to detect undone proposal applications. Note that I don't need to detect anything else but only proposal applications?
Third question: (If the answer to the second one is no) Is there a way to detect all undos as textual diffs? If this is possible, I guess I could also compare this diff with the latest proposal application diff to see if they are equal (and maybe write my own undo detector).
Thanks in advance, best regards,
FUDForum. Page generated in 1.03110 seconds
