Home » Modeling » GMF (Graphical Modeling Framework) » [GMF] Cannot open input element
[GMF] Cannot open input element [message #768134] Mon, 19 December 2011 11:27 Go to next message
Hello again,
im working with a Model using two kinds of nodes.
In emfatic the model looks like this (just a short piece of it).
@gmf.node(label="identifier", border.width="2", border.color="0,0,0", size="130,50", figure="rectangle", label.icon="false")
class Goal extends StandardNode {
  ref AwayGoal[*]#ReferencedGoal isReferencedByAwayGoals;
@gmf.node(label="identifier", border.width="1", border.color="0,0,0", size="130,50", label.icon="false", figure="rectangle")
class AwayGoal extends StandardNode {
  ref Goal[1]#isReferencedByAwayGoals ReferencedGoal;
  attr String AwayGoalModuleIdentifier;
@gmf.node(label="identifier")
class StandardNode {
  attr String identifier;
  attr String path;
  attr String content;
So i got a bidirectional relation between AwayGoal and Goal. Each AwayGoal must be assigned to one Goal.
And each Goal can be assigned to many AwayGoals.
This should work also between 2 instances of my Model.
Now i wont a Listener on my AwayGoals Objects.
Everytime when the ReferencedGoal is changed it should do something.
Here the specific Attribute of the AwayGoal should be set to the identifier of the referencedGoal.
I do this like this in my AwayGoalImpl Construction.
protected AwayGoalImpl()
    super();
	EContentAdapter adapter = new EContentAdapter() {
		public void notifyChanged(Notification notification) {
			if(notification.getFeature() instanceof EReferenceImpl
					&&notification.getNewValue() != null)
				Goal localReferencedGoal = (Goal) notification.getNewValue();
				TransactionUtil.getEditingDomain(notification.getNotifier()).getCommandStack().execute(
						new SetCommand(TransactionUtil.getEditingDomain(notification.getNotifier()),
								(EObject)notification.getNotifier(),
								GsnModelPackage.Literals.AWAY_GOAL__AWAY_GOAL_MODULE_IDENTIFIER,
								localReferencedGoal.getIdentifier()));
	this.eAdapters().add(adapter);
This works great now if i create these references inside a single instance which means one file.
If i now create the AwayGoal in one file(default.gsnmodel) and the Goal in the other(default2.gsnmodel),import the resource default2.gsnmodel in default.gsnmodel and set the Goal in my AwayGoal it still works.
But if i want to open the other File(default2.gsnmodel) now, containing the referencedGoal i got the following popup.
Cannot open input element.
Value 'gsnModel.impl.AwayGoalImpl@5c76d06a (eProxyURI: platform:/resource/testing/default.gsnmodel_diagram#_8ecCkCpZEeGsuMg9LAaJ2A)' is not legal. (platform:/resource/testing/default2.gsnmodel_diagram, 5, 118)
And the following exception:
!ENTRY org.eclipse.ui 4 0 2011-12-19 17:20:46.378
!MESSAGE Unable to create editor ID gsnModel.diagram.part.GsnModelDiagramEditorID: org.eclipse.core.runtime.CoreException: ERROR
!STACK 1
	at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.DiagramDocumentEditor.createPartControl(DiagramDocumentEditor.java:1509)
	at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
	at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
	at org.eclipse.ui.internal.EditorReference.getEditor(EditorReference.java:289)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2945)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
	at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
	at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2764)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
	at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:355)
	at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:164)
	at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:249)
	at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:228)
	at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:275)
	at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:251)
	at org.eclipse.jdt.internal.ui.packageview.PackageExplorerActionGroup.handleOpen(PackageExplorerActionGroup.java:376)
	at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$4.open(PackageExplorerPart.java:538)
	at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
	at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:866)
	at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
	at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
	at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
	at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
	at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1256)
	at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
	at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:269)
	at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:309)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
!SUBENTRY 1 org.eclipse.gmf.runtime.diagram.ui.resources.editor 4 1 2011-12-19 17:20:46.379
!MESSAGE ERROR
!ENTRY org.eclipse.ui 2 2 2011-12-19 17:20:46.389
!MESSAGE Ignored attempt to add saveable that was already registered
!STACK 0
org.eclipse.core.runtime.AssertionFailedException: unknown saveable: org.eclipse.ui.internal.DefaultSaveable@28b90dba from part: org.eclipse.ui.internal.ErrorEditorPart@28b90dba
	at org.eclipse.ui.internal.SaveablesList.logWarning(SaveablesList.java:187)
	at org.eclipse.ui.internal.SaveablesList.addModel(SaveablesList.java:117)
	at org.eclipse.ui.internal.SaveablesList.addModels(SaveablesList.java:289)
	at org.eclipse.ui.internal.SaveablesList.postOpen(SaveablesList.java:695)
	at org.eclipse.ui.internal.PartList.partOpened(PartList.java:234)
	at org.eclipse.ui.internal.PartList.access$0(PartList.java:210)
	at org.eclipse.ui.internal.PartList$1.propertyChanged(PartList.java:40)
	at org.eclipse.ui.internal.WorkbenchPartReference.fireInternalPropertyChange(WorkbenchPartReference.java:375)
	at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:610)
[Updated on: Mon, 19 December 2011 11:32] by Moderator
Re: [GMF] Cannot open input element [message #768159 is a reply to message #768134] Mon, 19 December 2011 12:11 Go to previous messageGo to next message
Comments below.
On 19/12/2011 5:27 PM, Snakebyte wrote:
> Hello again,
> attr String path;
> super();
You understand that an EContentAdapter attaches itself to all objects in
the containment tree, not just to a single object, right.
You understand that by not calling super, you're completely defeating
the purpose of a content adapter?
> if(notification.getFeature() instanceof EReferenceImpl)
Why are you testing against an implementation class rather than against
EReference?
> new
It seems likely you'll be executing a command in the middle of executing
the command that caused this notification. Probably not much good will
come of that.
> it still works.
If you have bidirectional references between files you need to save both
files when you add such a reference. Are you doing that?
> 5, 118)
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> !MESSAGE ERROR
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: [GMF] Cannot open input element [message #771510 is a reply to message #768134] Tue, 27 December 2011 08:33 Go to previous message
>> super();
Is there any Adapter that just attaches to the current Object ?
I think i have to use a normal Adapter then ?
I think if i use a normal Adapter i dont need the super call?
>EReference?
Hmm ok i should test against EReference.
>> new
>come of that.
What Command do you mean ? the getIdentifier Command ?
Previous Topic:Embedded diagram doesn't appear
Next Topic:Saving GMF Editor programmatically
Current Time: Sun Jul 20 15:01:48 EDT 2025
Powered by FUDForum. Page generated in 0.03631 seconds
