Home » Modeling » GMF (Graphical Modeling Framework) » [GMF] Create Undefined ??
[GMF] Create Undefined ?? [message #764560] Mon, 12 December 2011 07:35 Go to next message
Hello everybody.
I already asked it in the forums of Epsilon, but i got the answer that it is more a GMF related question.
I created a Modell like that :
I have one object goal. This goal can reference more goals, but with 2 different relations.
When i now draw a link in canvas with the small rectangles at everynode (drag and drop)
i get 2 proposals.
I can "Create Undefined" and "Create Undefined".
This names appear in the title of the porperty view as well.
How i can change these names ?
The Epsilon Forum proposes to change this in plugin.properties file of xyz.diagram projekt.
I did that. But nothing changes. What im doing wrong ?
And can anybody tell me where i can change the picture as well ?
Here is the link of the other thread in epsilon forum:
http://www.eclipse.org/forums/index.php/t/265016/
Greetings
Snakebyte
[Updated on: Mon, 12 December 2011 07:37] by Moderator
Re: [GMF] Create Undefined ?? [message #765114 is a reply to message #764560] Tue, 13 December 2011 07:56 Go to previous messageGo to next message
no ideas ?
Re: [GMF] Create Undefined ?? [message #765121 is a reply to message #765114] Tue, 13 December 2011 08:07 Go to previous messageGo to next message
Could it be that bug? https://bugs.eclipse.org/bugs/show_bug.cgi?id=354467
http://mickaelistria.wordpress.com
http://twitter.com/#!/mickaelistria
http://www.petalslink.com
Re: [GMF] Create Undefined ?? [message #765122 is a reply to message #765114] Tue, 13 December 2011 08:10 Go to previous messageGo to next message
Yes maybe it is.
It doesnt matter what i set in plugin.properties.
The value changes sometimes, and sometimes not Sad
Can you plz give me a short explanation on how to fix this ?
[Updated on: Tue, 13 December 2011 08:34] by Moderator
Re: [GMF] Create Undefined ?? [message #765152 is a reply to message #765122] Tue, 13 December 2011 09:17 Go to previous messageGo to next message
I did the following to fix this for my case.
In your plugin where you define the genmodel:
1) Create a folder called transformations
2) create a file called postRec.qvto
3) Place this content in the file
modeltype GMFGEN uses gmfgen('http://www.eclipse.org/gmf/2009/GenModel');
transformation postRec(inout gmfgenModel : GMFGEN);
main() {
--Fix the Create Undefined Bug 354467
gmfgenModel.objectsOfType(GenLink)->asOrderedSet()
 ->select(l | l.elementType.oclIsTypeOf(SpecializationType) and l.elementType.displayName = 'Undefined')->forEach(link)
   link.elementType.displayName := link.modelFacet.oclAsTyp(FeatureLinkModelFacet).metaFeature.ecoreFeature.name.firstToUpper();
4) Delete your genmodel
5) Generate your genmodel but check on the last page of the wizzard "Extra in-place gmfgen transformation after a reconcile step"
6) Put the text box below: platform:/resource/plugin-id/transformations/postRec.qvto
7) Delete .properties file in generated plugin (Otherwise changes do not take effect)
8) Generate code from genmodel
This should fix your problem.
Ralph
[Updated on: Tue, 13 December 2011 09:17] by Moderator
Re: [GMF] Create Undefined ?? [message #765190 is a reply to message #765152] Tue, 13 December 2011 10:30 Go to previous messageGo to next message
Works. Great. Thank you.
But if i do that, i lose my validate option under Edit ? Why ?
Do you know where i can set these pictures as well ?
[Updated on: Tue, 13 December 2011 10:33] by Moderator
Re: [GMF] Create Undefined ?? [message #766230 is a reply to message #765190] Thu, 15 December 2011 07:20 Go to previous messageGo to next message
did you try to exchange the files for creation in your .edit plugin generated by EMF. It should be named something like xxx.edit/icons/full/ctool16. It is possible that you might not have validation enabled set to true. Use this line in your transformation
genDiagram := gmfgenModel.objectsOfType(GenDiagram)->asOrderedSet()->first();
genDiagram.validationEnabled := true;
Outside of main you should of course define gendiagram as follows:
property genDiagram : GenDiagram = null;
Ralph
Re: [GMF] Create Undefined ?? [message #766233 is a reply to message #766230] Thu, 15 December 2011 07:22 Go to previous message
An example for my whole transformation can be found here:
http://code.google.com/a/eclipselabs.org/p/melanie/source/browse/de.uni_mannheim.informatik.swt.gmf.plm/transformations/postRec.qvto
[Updated on: Thu, 15 December 2011 10:27] by Moderator
Previous Topic:How to set properties of an object automatically when it is created in the diagram?
Next Topic:OCL Validation Error not correctly raised!!! (Update: Please delete this post!)
Current Time: Sat Jul 19 18:48:43 EDT 2025
Powered by FUDForum. Page generated in 0.08465 seconds
