Home » Language IDEs » ServerTools (WTP) » access include path from inferrence provider?
access include path from inferrence provider? [message #762257] Wed, 07 December 2011 14:10 Go to next message
I'm implementing a custom InferrenceProvider and am stuck in #applysTo.
To make a decision I need to have a look at the libraries of the project
the file is in. But I see no way to access it. Am I missing something?
Cheers
Philippe
Re: access include path from inferrence provider? [message #762278 is a reply to message #762257] Wed, 07 December 2011 14:53 Go to previous messageGo to next message
It's not directly tied to that interface, as there are already ways to get at which libraries a project uses [IJavaScriptProject#getResolvedIncludepath()]. IInferenceFile provides a filename, or rather a path to the file. There's no information given about whether that's a system location or a path in the workspace, but that should also be something that can be figured out.
Re: access include path from inferrence provider? [message #762516 is a reply to message #762278] Thu, 08 December 2011 03:31 Go to previous messageGo to next message
Do you have some pointers to get me started? How do I get the
IJavaScriptProject of a IInferenceFile?
Cheers
Philippe
Re: access include path from inferrence provider? [message #764759 is a reply to message #762516] Mon, 12 December 2011 14:53 Go to previous messageGo to next message
The character array for the filename can be converted into a String,
turned into a Path, and then used with the normal IWorkspaceRoot methods
to find whether it's a path in the workspace or a system location. If
it's the former, finding the project is straightforward.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Re: access include path from inferrence provider? [message #765604 is a reply to message #764759] Wed, 14 December 2011 06:16 Go to previous messageGo to next message
Philippe
Re: access include path from inferrence provider? [message #767924 is a reply to message #762278] Mon, 19 December 2011 03:03 Go to previous messageGo to next message
Ok, I have this more or less running. I'm a bit unsure about converting
from IProject to IJavaScriptProject though. First first check for
org.eclipse.wst.jsdt.core.jsNature and then do JavaScriptCore.create. Is
this the right way to do it? Is there a reason adapters don't work?
Cheers
Philippe
Re: access include path from inferrence provider? [message #768335 is a reply to message #767924] Mon, 19 December 2011 18:37 Go to previous messageGo to next message
JavaScriptCore#create() and IJavaScriptProject#.isExists() are the right way to go about it (although if you must check for the nature yourself, org.eclipse.wst.jsdt.core.JavaScriptCore#NATURE_ID is the constant to use). For adapters, are you sure you're using the right key?
Re: access include path from inferrence provider? [message #768471 is a reply to message #768335] Tue, 20 December 2011 03:09 Go to previous message
Uhm, no. This is the code I have:
IProject project = resource.getProject();
Object adapter1 = Platform.getAdapterManager().getAdapter(project,
IJavaScriptProject.class);
Object adapter2 = project.getAdapter(IJavaScriptProject.class);
both adapters end up being null.
Gruss
Philippe
Previous Topic:integrate WSDLEditor(org.eclipse.wst.wsdl.ui) into a rcp project.
Next Topic:Eclipce (3.5) + Tomcat 6 = frustration..
Current Time: Sun Jul 20 09:36:20 EDT 2025
Powered by FUDForum. Page generated in 0.05028 seconds
