Home » Archived » BIRT » Dynamic Report; No Values Appear
Dynamic Report; No Values Appear [message #763413] Fri, 09 December 2011 13:12 Go to next message
Any help would be appreciated:
I have a report structured as follows; A list where each item is a table. The table is 2 columns with item name and item value.
ID 2
Name Sam
ID 4
Name Sue
etc.
So I see the table created the expected number of times, e.g., I expect three return records and I see three tables. The field names are there. But the field values are blank.
I cannot paste the code in because it's on an internal network - but here's some snippets;
table.insertRow(new RowOperationParameters(2,-1,row));
RowHandle rowHandle = (RowHandle) table.getDetail(row);
CellHandle valueCell = (CellHandle) rowHandle.getCells().get(1); // value cell
TextItemHandle text = designFactory.newTextItem("someName");
text.setContentType(DesignChoiceContsants.TEXT_DATA_CONTENT_TYPE_HTML);
text.setContent("<VALUE-OF>row[\"FieldName\"]</VALUE-OF>");
valueCell.getContent().add(text);
Any ideas?
Re: Dynamic Report; No Values Appear [message #764657 is a reply to message #763413] Mon, 12 December 2011 10:49 Go to previous messageGo to next message
So you use a list item bound to your dataset and have a nested table in
the the list item detail row? If you you want labels for each row why
not use a grid instead of a table. Why are you inserting a row into the
table? Is the code that inserts the row called before the report is
executed or is it in an event?
Jason
> ID 2
> Name Sam
> ID 4
> Name Sue
> etc.
> value cell
> Any ideas?
Re: Dynamic Report; No Values Appear [message #765302 is a reply to message #764657] Tue, 13 December 2011 15:07 Go to previous messageGo to next message
Ok - I will try a grid.
Re: Dynamic Report; No Values Appear [message #765303 is a reply to message #765302] Tue, 13 December 2011 15:08 Go to previous messageGo to next message
Ok - I tried a grid instead of a table - same thing. The problem is that text.setContent("<VALUE-OF>row[\"FieldName\"]</VALUE-OF>"); does not produce a value.
Re: Dynamic Report; No Values Appear [message #765738 is a reply to message #765303] Wed, 14 December 2011 10:44 Go to previous messageGo to next message
John,
Is the text element in a table that is bound to a data set?
BTW are your setting?
text.setContentType( DesignChoiceConstants.TEXT_CONTENT_TYPE_HTML );
Jason
> produce a value.
Re: Dynamic Report; No Values Appear [message #765765 is a reply to message #765738] Wed, 14 December 2011 11:33 Go to previous message
Nope - that was the problem; did not bind properly to the dataset.
Jason Weathersby wrote on Wed, 14 December 2011 10:44
John,
Jason
> produce a value.
Previous Topic:Reg:Report Engine start and shutdown
Next Topic:Table grouping help
Current Time: Sat Jul 19 09:44:04 EDT 2025
Powered by FUDForum. Page generated in 0.06561 seconds
