Home » Modeling » EMF » [Teneo] How to have non-indexed n:m relations with named join-columns
[Teneo] How to have non-indexed n:m relations with named join-columns [message #765161] Tue, 13 December 2011 09:35 Go to next message
Hi all
I am trying to annotate my model to have an non-indexed many-to-many relationship with named join-columns.
According to [1],[2] this shall look something like this:
@ManyToMany(indexed=false)
@JoinTable(
   joinColumns=@JoinColumn(name="CUST_ID", referencedColumnName="ID"),
   inverseJoinColumns=@JoinColumn(name="PHONE_ID", referencedColumnName="ID")
public Set getPhones() { return phones; }
Unfortunately, this does not work. The n:m-table contains the index-column.
If I ommit the custom join-column names and thus only set indexed=false like below the n:m-table is non indexed (which would be ok except the non-custom-column names).
Does someone know, how to annotate the method to have non-indexed n:m mappings with custom join-column names?
I use EMF 2.5.0, Hibernate 3.4.0.GA, Teneo 1.1.2
(existing project)
I appreciate any hints or pointers!
Jan
[1] htp://docs.oracle.com/javaee/5/api/javax/persistence/ManyToMany.html
[2] htp://wiki.eclipse.org/Teneo/Hibernate/ModelRelational/Association_Mapping#Mapping_non-indexed_nm_relations
Re: [Teneo] How to have non-indexed n:m relations with named join-columns [message #765171 is a reply to message #765161] Tue, 13 December 2011 09:49 Go to previous messageGo to next message
Hi Jan,
It seems that you are annotating the java source code, Teneo uses model annotations, these need to be specified in the
ecore model:
http://wiki.eclipse.org/Teneo/Hibernate/ModelRelational/Annotations_Format
If you are using EMF server side then the following EMF project maybe of interest, it generates annotations in the java
code which can be manually changed, see here for a blog post:
http://martintaal.wordpress.com/2011/10/26/texo-generate-jpa-annotated-pojos-from-ecorexsd/
It also has other differentiators compared to EMF:
http://martintaal.wordpress.com/2011/12/06/emft-texo-different-from-emf-code-generation/
gr. Martin
On 12/13/2011 03:35 PM, Jan Haensli wrote:
> Hi all
> @JoinTable(
> (existing project)
> Jan
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] How to have non-indexed n:m relations with named join-columns [message #765177 is a reply to message #765171] Tue, 13 December 2011 10:07 Go to previous messageGo to next message
Hi Martin
Thanks for the quick reply!
Sorry, for the mistake/confusion:
I am using model annotations, but for the sake of simplicity I pasted adapted examples from the JPA doc.
Actually, what I have is this:
     * @return
     * @model annotation="teneo.jpa appinfo='@ManyToMany(indexed=false) @JoinTable(indexed=false joinColumns=
     * @JoinColumn(name="COMPENSATIONACCOUNT_ID", referencedColumnName="ID"), inverseJoinColumns=
     * @JoinColumn(name="SHARECLASS_ID", referencedColumnName="ID") )'"
    EList<ShareClass> getAssignedShareClasses();
The above "annotations" work, except that the n:m-table contains the index column.
Thanks for looking at this again.
Jan
Re: [Teneo] How to have non-indexed n:m relations with named join-columns [message #765186 is a reply to message #765177] Tue, 13 December 2011 10:18 Go to previous messageGo to next message
Isn't the index column created because your list is marked as ordered?
Hence it is mapped to list in hbm.xml and not a bag.
Simply set the ordered =false in your ecore.
Tom
Am 13.12.11 16:07, schrieb Jan Haensli:
> Hi Martin
> * @return
> index column.
> Jan
Re: [Teneo] How to have non-indexed n:m relations with named join-columns [message #765191 is a reply to message #765186] Tue, 13 December 2011 10:29 Go to previous messageGo to next message
Yes setting ordered to false helps and there is a persistence option to let all lists to be mapped as a bag (so without
an index), which can be used.
Still strange that the indexed=false is not picked up. Note that after adding/changing annotations in the model you have
to regenerate the source code as the annotations are then present at runtime.
gr. Martin
> Tom
>> Hi Martin
>> * @return
>> index column.
>> Jan
The Netherlands
Re: [Teneo] How to have non-indexed n:m relations with named join-columns [message #765276 is a reply to message #765191] Tue, 13 December 2011 13:50 Go to previous messageGo to next message
Hi Tom, Martin
Changing the ecore property "ordered" to "false" works! Thanks!
As I use the Java model as a base for all settings I need a way to set ordered=false on my EMF model. (Otherwise after regenerating the model the setting is lost)
@model ordered="false"
does not seem to work. Any idea how I have to annotate the java model to have ordered=false on the ecore model?
I do reload and re-generate the model each time I amend the annotations on the Java EMF Model. But as mentioned, indexed=false seems to be ignored, when the @JoinTable annotation is there as well.
Cheers
Jan
Re: [Teneo] How to have non-indexed n:m relations with named join-columns [message #765566 is a reply to message #765276] Wed, 14 December 2011 05:06 Go to previous message
Jan,
Comments below.
On 13/12/2011 7:50 PM, Jan Haensli wrote:
> Hi Tom, Martin
It works for me. I'm not sure what the problem might be without more
information.
> Cheers
> Jan
Previous Topic:[EMF Compare] EMFCompare is useless in EGit's merge tool?
Next Topic:[Teneo] combining a @ManyToMany and a @OneToMany between 2 entities, how to?
Current Time: Sun Jul 20 12:54:00 EDT 2025
Powered by FUDForum. Page generated in 0.05523 seconds
