Home » Eclipse Projects » Target Management » Explore remote functions while working on a remote project(RSE, work remote , explore remote functions)
Explore remote functions while working on a remote project [message #765010] Tue, 13 December 2011 03:58 Go to next message
I have a question I didn't find an answer to:
While working on a remote project using eclipse RSE(TM) or Aptana (it doesnt really matter, answer for any of them will be good) I couldn't find a way to locate functions implementation or location.
For example:
Lets say im working on a remote project in the file a_func.php, and in that file there is a use in the function b_func(...) which is implemented in another file that is being included to the current file I am working on.
If I was working on a local file system, usually something like 'ctrl+mouse_click' would take me to its definition/decleration.
While working remotely it doesnt work.
Does someone know how to make it happen?? ^_^
Thanks!
Re: Explore remote functions while working on a remote project [message #766370 is a reply to message #765010] Thu, 15 December 2011 10:41 Go to previous messageGo to next message
When you say you're working on a remote project, I assume you're using EFS
with RSE as opposed to just RSE. If not, then you're probably not getting
this project support because RSE is separate from regular Eclipse projects.
If so, what kind of project are you working with (what project natures are
included in the .project file)?
"Elior" <forums-noreply@eclipse.org> wrote in message
news:jc7433$p39$1@news.eclipse.org...
> For example:
> on. If I was working on a local file system, usually something like
> 'ctrl+mouse_click' would take me to its definition/decleration. While
> working remotely it doesnt work. Does someone know how to make it happen??
> ^_^ Thanks!
Re: Explore remote functions while working on a remote project [message #767565 is a reply to message #766370] Sun, 18 December 2011 05:42 Go to previous messageGo to next message
ummm, the natures of the aptana are:
<natures>
<nature>com.aptana.editor.php.phpNature</nature>
<nature>com.aptana.projects.webnature</nature>
</natures>
If I have to describe the behavior of the system it is as if there is not any project environment that was built what so ever as oppose to local projects which the eclipse build (I guess) a local environment with variables and functions table and more...
Re: Explore remote functions while working on a remote project [message #768071 is a reply to message #767565] Mon, 19 December 2011 09:21 Go to previous message
Since this works for a local project but not for the equivalent EFS-based
remote project, my guess is that Aptana tries to access files using
underlying local files rather than at the IFile level. In remote RSE-EFS
cases, there are no such files so that would not work. That said, I have
not used Aptana so I don't know for sure whether that's how it's
implemented.
news:jckg3m$8d2$1@news.eclipse.org...
> <natures>
> </natures>
Previous Topic:ftp set defualt to passive
Next Topic:Add custom UI to access Serial Port
Current Time: Sun Jul 20 11:49:12 EDT 2025
Powered by FUDForum. Page generated in 0.03247 seconds
