Home » Modeling » TMF (Xtext) » log info from FeatureCallCompiler
log info from FeatureCallCompiler [message #764617] Mon, 12 December 2011 09:38 Go to next message
In my DSL I'm using XbaseCompiler for generating Java code related to
XExpressions; when FeatureCallCompiler is (implicitly) invoked for
translating feature accesses and the receiver is a parameter (which is
correctly scoped) I get a log info
0 [main] INFO .xbase.compiler.FeatureCallCompiler - The variable
'newExp' has not been declared.
where 'newExp' is a (reference to a) parameter
this comes from
protected void _toJavaExpression(XAbstractFeatureCall call, IAppendable b) {
if (b.getName(call.getFeature()) == null) {
String variableName = getFavoriteVariableName(call.getFeature());
if (log.isInfoEnabled())
log.info("The variable '"+variableName+"' has not been declared.");
b.declareSyntheticVariable(call.getFeature(), variableName);
I suppose it is only an info but not an actual error/warning, right?
I just wanted to be sure that everything is working correctly
thanks in advance
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: log info from FeatureCallCompiler [message #764630 is a reply to message #764617] Mon, 12 December 2011 09:56 Go to previous messageGo to next message
Hi Lorenzo,
please make sure that your appendable was properly initialized before
you try to compile the method body.
You should invoke #declareVariable for all parameters and other
implicitly available identifiables. Please refer the the
JvmModelGenerator for details.
Sebastian
Am 12.12.11 15:38, schrieb Lorenzo Bettini:
> Hi
> this comes from
> b) {
> thanks in advance
> Lorenzo
Re: log info from FeatureCallCompiler [message #765012 is a reply to message #764630] Tue, 13 December 2011 03:58 Go to previous messageGo to next message
On 12/12/2011 03:56 PM, Sebastian Zarnekow wrote:
> Hi Lorenzo,
Hi Sebastian
actually the generation works (as I said the parameters are correctly
scoped); however, I should declareVariable for each parameter? What
could go wrong otherwise? Just to understand better :)
thanks
Lorenzo
Re: log info from FeatureCallCompiler [message #765072 is a reply to message #765012] Tue, 13 December 2011 06:09 Go to previous messageGo to next message
Hi Lorenzo,
you could end up with name clashes in the generated code.
Sebastian
Am 13.12.11 09:58, schrieb Lorenzo Bettini:
>> Hi Lorenzo,
> Hi Sebastian
> thanks
> Lorenzo
Re: log info from FeatureCallCompiler [message #765127 is a reply to message #765072] Tue, 13 December 2011 08:19 Go to previous message
On 12/13/2011 12:09 PM, Sebastian Zarnekow wrote:
> Hi Lorenzo,
> Regards,
> Sebastian
OK, got it! :)
thanks again
Lorenzo
Previous Topic:Strange scoping behaviour
Next Topic:[Xtext 2.2] Editor does not work out of the box
Current Time: Sat Jul 19 09:20:19 EDT 2025
Powered by FUDForum. Page generated in 0.03404 seconds
