Problem on create own lib plugin [message #764394] |
Sun, 11 December 2011 23:47 |
I'm writing a RCP application using Eclipse 3.7.1 and I use spring and hibernate in my application. I put all these lib file in the "lib" folder and specify all these files in the classpath section. It's all fine when they are in same plugin.
And now I want to put all these libraries to seperate plugin, since it can be shared with other application also. So I create a new plugin project by choosing "plugin from existing jar archive" and add all the jar files under "lib" folder. And then I add all exported package in runtime page. At last, I had added Quote:Eclipse-BuddyPolicy: registered in my lib plugin and added Quote:Eclipse-RegisterBuddy: com.rainbow.spring-hibernate-annotation in my application. In my application, I add this new plugin in required-plugin section under dependencies page. However an error message occurred as below when I run the program.
Caused by: org.springframework.beans.factory.BeanDefinitionStoreException: Unexpected exception parsing XML document from class path resource [app-context.xml]; nested exception is javax.xml.parsers.FactoryConfigurationError: Provider for javax.xml.parsers.DocumentBuilderFactory cannot be found
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:412)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:334)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:302)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:143)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:178)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:149)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:212)
at org.springframework.context.support.AbstractXmlApplicationContext.loadBeanDefinitions(AbstractXmlApplicationContext.java:126)
at org.springframework.context.support.AbstractXmlApplicationContext.loadBeanDefinitions(AbstractXmlApplicationContext.java:92)
at org.springframework.context.support.AbstractRefreshableApplicationContext.refreshBeanFactory(AbstractRefreshableApplicationContext.java:130)
at org.springframework.context.support.AbstractApplicationContext.obtainFreshBeanFactory(AbstractApplicationContext.java:467)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:397)
at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:139)
at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:83)
at com.rainbow.claim.Activator.start(Activator.java:42)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
... 34 more
Caused by: javax.xml.parsers.FactoryConfigurationError: Provider for javax.xml.parsers.DocumentBuilderFactory cannot be found
at javax.xml.parsers.DocumentBuilderFactory.newInstance(Unknown Source)
at org.springframework.beans.factory.xml.DefaultDocumentLoader.createDocumentBuilderFactory(DefaultDocumentLoader.java:89)
at org.springframework.beans.factory.xml.DefaultDocumentLoader.loadDocument(DefaultDocumentLoader.java:70)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:388)
... 51 more
Can anyone help me out?
FUDForum. Page generated in 0.11549 seconds
