Home » Modeling » TMF (Xtext) » content assist across files(can one create template proposals across files)
content assist across files [message #763432] Fri, 09 December 2011 13:54 Go to next message
if i have an autocompletion that lists all elements for some rule, now if i defined another dsl file with some aditional elements, can the autocompletion list all proposals from the two dsl files?
Thank you,
Mokhtar
Re: content assist across files [message #763446 is a reply to message #763432] Fri, 09 December 2011 14:41 Go to previous messageGo to next message
i do not understand your question. it would be helpful if youd explain it with an example
~Christian
Re: content assist across files [message #763452 is a reply to message #763446] Fri, 09 December 2011 15:00 Go to previous messageGo to next message
ok sorry.
Grammar is:
MyRule: 'Hey du ' Person;
Person: name = ID;
assume now that this code in model1.dsl:
Hey du mokhtar
Hey du tim
and this in model2.dsl
Hey du john
Hey du anne
if i used the content assist stub for MyRule to list the person names, could this list them across the two files?
Hope i convey it correctly!
Mokhtar
Re: content assist across files [message #763457 is a reply to message #763452] Fri, 09 December 2011 15:13 Go to previous messageGo to next message
yes e.g. by querying the index (via ResourceDescriptionsProvider). but please note: i still dont understand why you dont use cross references. this would give you everyting for free!!!!!!!!!!
~Christian
Re: content assist across files [message #763464 is a reply to message #763457] Fri, 09 December 2011 15:27 Go to previous messageGo to next message
Thank you! could you please tell me where and how to use the "ResourceDescriptionsProvider"?
for your question, actually, i am making dsl for prolog like language, given:
ct(head,condition(true),idcreation(skip),transformation(add(getter))).
ct(copyField(Field1,Field2,V),condition(true),idcreation(skip),transformation(replace(Field1,Field2))).
ctseq(doStuff,ct(head)).
ctseq(doStuff2,ct(copyField(F,F,value))).
those were say 4 prolog facts, in the third and fourth you note that i reused ct(head) and ct(copyField(..)) from their defining facts above. So i can't easily reference that part of prolog fact to the other fact providing at same time flexibility to user to change the arguments. SO prolog is type unsafe and you should beable in same program to change the structure of the predicates, so cross-reference FAILED Sad and i think to do that job in IDE runtime
Thank you,
Mokhtar
Re: content assist across files [message #763466 is a reply to message #763464] Fri, 09 December 2011 15:33 Go to previous messageGo to next message
here a simple example
Model:
	greetings+=Greeting*;
Greeting:
	'Hello' name=ID value=ID '!';
public class MyDslProposalProvider extends AbstractMyDslProposalProvider {
	@Inject
	ResourceDescriptionsProvider rdp;
	public void completeGreeting_Value(EObject model, Assignment assignment,
			ContentAssistContext context, ICompletionProposalAcceptor acceptor) {
		IResourceDescriptions rd = rdp.getResourceDescriptions(model.eResource());
		for (IEObjectDescription d : rd.getExportedObjectsByType(MyDslPackage.Literals.GREETING)) {
			acceptor.accept(createCompletionProposal(d.getQualifiedName().toString(), context));
for perf reasons you may habe to add stuff to the user data of the ieobjectdesription using a custom DefaultResourceDescriptionStrategy
and store the information about the params there.
(use EObjectDescription.create(qualifiedName, eObject, userData) in the code.
alternatively you would have to do proxy resolving on IEObjectDescription.getEObjectOrProxy
which might be perf hell when having many/big files
~Christian
Re: content assist across files [message #763473 is a reply to message #763466] Fri, 09 December 2011 15:44 Go to previous messageGo to next message
Thank you so much for this valuable help. We won't be having big files in our new DSL because it is declarative.
Gute Nacht,
Mokhtar
Re: content assist across files [message #763474 is a reply to message #763473] Fri, 09 December 2011 15:47 Go to previous message
Just to be complete here a demo of the strategy
Model:
Greeting:
	'Hello' name=ID number=INT value=ID '!';
public class MydslResourceDescriptionStrategy extends
		DefaultResourceDescriptionStrategy {
	public boolean createEObjectDescriptions(EObject eObject,
			IAcceptor<IEObjectDescription> acceptor) {
		if (getQualifiedNameProvider() == null)
			return false;
		try {
			QualifiedName qualifiedName = getQualifiedNameProvider().getFullyQualifiedName(eObject);
			if (qualifiedName != null) {
				Map<String, String> userData = new HashMap<String, String>();
				if (eObject instanceof Greeting) {
					userData.put("number", ((Greeting)eObject).getNumber()+"");
				acceptor.accept(EObjectDescription.create(qualifiedName, eObject, userData ));
		} catch (Exception exc) {
		return true;
public class MyDslRuntimeModule extends org.xtext.example.mydsl.AbstractMyDslRuntimeModule {
	public Class<? extends IDefaultResourceDescriptionStrategy> bindIDefaultResourceDescriptionStrategy() {
		return MydslResourceDescriptionStrategy.class;
	@Inject
			acceptor.accept(createCompletionProposal(d.getQualifiedName().toString()+d.getUserData("number"), context));
Previous Topic:[Xtext 2.2] NPE in JvmMemberRenameStrategy in a JDT project
Next Topic:[Xtext 2.1.1] interface segregation
Current Time: Sat Jul 19 09:52:12 EDT 2025
Powered by FUDForum. Page generated in 0.28798 seconds
