Home » Archived » EGL Development Tools » Discrepancy in the tutorial??
Discrepancy in the tutorial?? [message #763065] Thu, 08 December 2011 23:52 Go to next message
EDT:Tutorial: RUI With DataBase Lesson 2
Create the PaymentService project
The tutorial clearly says to set up the service to use the java generator.
However, when I had a problem, the solution was to go back and change the properties to use the JavaScript generator.
Is this an error in the tutorial or am I missing something?
[Updated on: Fri, 09 December 2011 00:03] by Moderator
Re: Discrepancy in the tutorial?? [message #763180 is a reply to message #763065] Fri, 09 December 2011 04:53 Go to previous messageGo to next message
I think I've resolved this. I think the tutorial is correct for creating the service. But, I think the tutorial may have the wrong image where it is instructing how to create the PaymentFileMaintenance handler. I think it should show selecting the Web 2.0 application with services as well as stating so in the instructions where it current says "basis". I think that may be a typo. Maybe someone can correct me, if I'm wrong.
Thanks, Bob
Re: Discrepancy in the tutorial?? [message #763234 is a reply to message #763180] Fri, 09 December 2011 06:51 Go to previous messageGo to next message
Bob,
I think the part 'Use the EGL SQL retrieve feature to create a Record type' in http://wiki.eclipse.org/EDT:Tutorial:_RUI_With_DataBase_Lesson_3 attached a wrong screen-shot. The record PAYMENT should be created in PaymentShared project, so that you don't need to change the settings of service project. From the description for the projects, since the record will be used in both handler & service, then the PAYMENT should be created in PaymentShared.
I'll check with author see if this is the problem.
Rocky
Re: Discrepancy in the tutorial?? [message #763328 is a reply to message #763065] Fri, 09 December 2011 10:23 Go to previous messageGo to next message
Thanks, Rocky. In Paul's absence, I'll try this out and make whatever correction is appropriate.
Re: Discrepancy in the tutorial?? [message #764735 is a reply to message #763328] Mon, 12 December 2011 14:13 Go to previous message
Rocky is correct.
The paymentRec definition needs to be created in the PaymentShared project so that it will be generated for both Java and JavaScript environments.
The tutorial has been updated.
Previous Topic:Possible Suggestions for Tools
Next Topic:[Solved] Language elements not supported in EDT - Called Program
Current Time: Sun Jul 20 02:52:20 EDT 2025
Powered by FUDForum. Page generated in 0.04237 seconds
