Home » Eclipse Projects » Plugin Development Environment (PDE) » How to debug PDE ant task for building?
How to debug PDE ant task for building? [message #762149] Wed, 07 December 2011 11:00 Go to next message
My latest issue is that the ant pde task fails to pick up a couple of my
plugins and features out of the 20 or so I have, it does not build the
@dot directory so later tasks fail. pde gives no debug output that might
help me.
Like most I don't really want to have to debug pde to find out why, it
should have some form of debug mode where it logs all it's steps. The
weird thing is I have a colleague who has theh exact same checkout as I
do and his works mine doesn't. We even went to the length of checking in
his eclipse install so I could checkout and make sure I was identical.
It worked a few days ago so I restored to the version of eclipse I was
using then, no change. Here are theh pertinent aparts of my build.xml
<target name="init" unless="init.done">
<mkdir dir="${work.dir}/plugins" />
<mkdir dir="${buildDirectory}" />
<delete includeemptydirs="true">
<fileset dir="${work.dir}/plugins" includes="**/*"/>
</delete>
<copy todir="${work.dir}/plugins">
<fileset dir="${workspace.dir}/edmui">
<include name="com.yambina.drools.lib/**" />
<include name="com.yambina.edm.cdoserver/**" />
<include name="com.yambina.edm.commons/**" />
<include name="com.yambina.edm.commons-logging.cfg/**" />
<include name="com.yambina.edm.core/**" />
<include name="com.yambina.edm.etldesigner/**" />
<include name="com.yambina.edm.lib/**" />
<include name="com.yambina.edm.log/**" />
<include name="com.yambina.edm.log.log4j/**" />
<include name="com.yambina.edm.log4j.cfg/**" />
<include name="com.yambina.edm.validation/**" />
<include name="com.yambina.edmmodel/**" />
<include name="com.yambina.edmmodel.edit/**" />
<include name="com.yambina.mdwmui/**" />
<include name="com.yambina.mdwmui.drools.eclipse/**" />
<include name="com.yambina.etloda/**" />
<include name="com.yambina.etlodaui/**" />
<include name="org.drools.eclipse-5.2.0.Final/**" />
<exclude name="*/bin/**" />
<exclude name="*/target/**" />
<exclude name="*/.settings/**" />
<exclude name="*/.classpath" />
<exclude name="*/.project" />
<exclude name="*/.options" />
<exclude name="**/*.class" />
</fileset>
</copy>
<target name="build.EDMUI" depends="init">
<delete dir="${buildDirectory}/EDMUI"/>
<pde run="-buildfile
${ajdt.pdebuild.scripts}/productBuild/productBuild.xml
-Dajdt.pdebuild.home=${ajdt.pdebuild.home}
-Dajdt.pdebuild.scripts=${ajdt.pdebuild.scripts}
-Dproduct=/com.yambina.mdwmui/EDMUI.product" name="EDMUI" />
<foreach list="${configs}" delimiter="&amp;" trim="true"
target="post.build.EDMUI" param="type" inheritall="true" />
<post.build.clean/>
</target>
Thx.
David
Re: How to debug PDE ant task for building? [message #762179 is a reply to message #762149] Wed, 07 December 2011 11:53 Go to previous message
http://eclipse-debug.blogspot.com/2011/01/debugging-ant-tasks-with-self-hosting.html
PDE does have some tracing options, easiest way to see them is to create a new Eclipse Application launch configuration and look at the tracing tab.
PDE Core uses PDE Build to create the build scripts then executes the ant tasks so we do not get direct feedback on progress/problems. If ant encounters problems it dumps them to a log file which PDE Core later parses.
Previous Topic:Debug mode not working
Next Topic:unknown saveable assertation on reopening a custom editor
Current Time: Sat Jul 19 12:03:57 EDT 2025
Powered by FUDForum. Page generated in 0.04082 seconds
