Home » Modeling » OCL » Run CompleteOCL Validation manually
Run CompleteOCL Validation manually [message #761331] Tue, 06 December 2011 04:51 Go to next message
Hi there,
I try to execute CompleteOLC validation of some of my EObjects
programmatically from some Eclipse code.
First, I have some Eclipse earlyStartup to register the OCL file
public void earlyStartup() {
URI oclURI = URI.createPlatformResourceURI("myPath",false);
EValidator validator =
new CompleteOCLEObjectValidator(MyPackage.eINSTANCE, oclURI);
EValidator.Registry.INSTANCE.put(MyPackage.eINSTANCE,validator);
This works fine for validation in the standard EMF tree editor. The OCL
constraints are working fine.
Now I do this from my own code:
MyEObject o = MyFactory.eINSTANCE.createMyEObject();
IValidator<EObject> validator =
ModelValidationService.getInstance()
.newValidator(EvaluationMode.BATCH);
IStatus status = validator.validate(infra);
Afterwards the status says:
"Status OK: org.eclipse.emf.validation code=10 No constraints were
evaluated. null"
Why are no constraints evaluated? Do I have to call validation differently?
Hauke
Re: Run CompleteOCL Validation manually [message #761354 is a reply to message #761331] Tue, 06 December 2011 05:37 Go to previous messageGo to next message
Hi Hauke
It's not clear to me that you have emulated the automated Eclipse plugin
registrations in your standalone code.
I have often found validations not occurring too. I find the best
approach is to run two debuggers; one on working code and the other on
non-working code, and see where they diverge.
Ed Willink
On 06/12/2011 09:51, Hauke Fuhrmann wrote:
> Hi there,
> @Override
> OCL constraints are working fine.
> evaluated. null"
> differently?
> Cheers,
> Hauke
Re: Run CompleteOCL Validation manually [message #761591 is a reply to message #761354] Tue, 06 December 2011 12:40 Go to previous messageGo to next message
Hi Ed,
note that I'm not using a standalone application. It is a usual Eclipse
Application.
I use the same earlyStartup code below for the standard EMF Tree Editor
as for my custom code (which is simply executed by pressing a Button).
I was inspired bythe Eclipse help
http://help.eclipse.org/indigo/topic/org.eclipse.ocl.doc/help/Integration.html?path=44_1_7_2#Integration-CompleteOCL
So I would think that registering the validators is correct.
So I guess I execute the validation wrong. Is there another way to call
the built-in validation for EMF?
Hauke
Am 06.12.2011 11:37, schrieb Ed Willink:
> Hi Hauke
> Regards
> Ed Willink
>> Hi there,
>> @Override
>> evaluated. null"
>> differently?
>> Cheers,
>> Hauke
Re: Run CompleteOCL Validation manually [message #761598 is a reply to message #761591] Tue, 06 December 2011 12:59 Go to previous message
HI Hauke
It's perhaps five years since I looked at EMFv. It never seemed to do
anything useful for me and as I now realize, it's OCL support was one of
many false starts that ultimately led to EMF delegates in Helios.
I always invoke validation using Diagnostician.validate.
Perhaps EMF validation has some bit rot. If you get
Diagnostician.validate to work you might care to report back on why
ModelValidationService is different.
Ed Willink
On 06/12/2011 17:40, Hauke Fuhrmann wrote:
> Hi Ed,
> Eclipse Application.
> Editor as for my custom code (which is simply executed by pressing a
> Button).
> call the built-in validation for EMF?
> Cheers,
> Hauke
>> Hi Hauke
>> Regards
>> Ed Willink
>>> Hi there,
>>> @Override
>>> evaluated. null"
>>> differently?
>>> Cheers,
>>> Hauke
Previous Topic:CompleteOCL validation step by step
Next Topic:OCL constraints in Ecore problems view messages
Current Time: Sat Jul 19 11:00:28 EDT 2025
Powered by FUDForum. Page generated in 0.04283 seconds
