Home » Eclipse Projects » Target Management » ftp set defualt to passive
ftp set defualt to passive [message #760657] Sat, 03 December 2011 17:41 Go to next message
I browsed through bug list and noticed that it is listed there from 2009 Smile 269442
I'm not a Java developer myself but I use RSE every day for about 1000 different ftp hosts and 90% of time I need to go trough the painful path setting a ftp connection to be passive. I work in a support line and it is not unusual for me to deal with 40 different ftp connections per day.
create a connection > wait it to fail > open subsystem properties > ftp properties > change to passive
it seems that change keeps delayed all the time. Can someone pinpoint me to a place where this setting is coded in or defined in this project so I could just change this and build my self a special version (even if i need to learn how to build this for just this change)
[Updated on: Sat, 03 December 2011 17:57] by Moderator
Re: ftp set defualt to passive [message #761074 is a reply to message #760657] Mon, 05 December 2011 16:05 Go to previous messageGo to next message
Hi Anton,
Given, an IHost for an ftp connection, you can set it to passive by using
this code:
IConnectorService conServ =
(IConnectorService)ftpHost.getConnectorServices()[0];
IPropertySet properties = conServ.getPropertySet("FTP Settings");
properties.addProperty("passive","true",PropertyType.getEnumPropertyType(new
String[]{"true","false"}));
Dave
"Anton" <forums-noreply@eclipse.org> wrote in message
news:jbe8jd$8t4$1@news.eclipse.org...
>I browsed through bug list and noticed that it is listed there from 2007
>:) 269442
> it seems that there is no intent to make a change in this case on this
> eclipse plugin. What I'm wondering is that can someone pinpoint me to a
> just change this and build my self a special version so i have this set by
> default today (even if i need to learn how to build this for just this
> change)
Re: ftp set defualt to passive [message #761318 is a reply to message #761074] Tue, 06 December 2011 04:33 Go to previous message
Thanks David i'll digg in
Previous Topic:programmatically use RSE
Next Topic:Explore remote functions while working on a remote project
Current Time: Sat Jul 19 06:05:44 EDT 2025
Powered by FUDForum. Page generated in 0.22275 seconds
