Home » Modeling » M2T (model-to-text transformation) » [ACCELEO] Argument cannot be null
[ACCELEO] Argument cannot be null [message #760604] Sat, 03 December 2011 07:02 Go to next message
I am using ACCELEO 3.2 and Eclipse Indigo ServicePack1. When ACCELEO generator runs, Transformation file is generated. But, exception java.lang.IllegalArgumentException is occured. Strange thing is that (same code is tested with Acceleo 3.1 and it doesn't produce any problem)
For simplicity, I am creating a simple Acceleo project with UI launcher (in Acceleo 3.2). My simple .mtl file is :
[comment encoding = UTF-8 /]
[module generate('http://www.eclipse.org/uml2/3.0.0/UML')]
[template public generateElement(aModel : Model)]
[comment @main/]
[file (aModel.name, false, 'UTF-8')]
// ACCELEO Transformation
[/file]
[/template]
But, when ACCELEO UI launcher is triggered, java.lang.IllegalArgumentException is thrown ( and error message listed below is printed at console)
!ENTRY org.eclipse.jface 4 0 2011-12-03 12:46:54.702
!MESSAGE Unhandled event loop exception during blocked modal context.
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.IllegalArgumentException: Argument cannot be null)
at org.eclipse.swt.SWT.error(SWT.java:4282)
at org.eclipse.swt.SWT.error(SWT.java:4197)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:138)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.block(ModalContext.java:173)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:388)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:275)
at org.eclipse.ui.internal.progress.ProgressManager$5.run(ProgressManager.java:960)
at org.eclipse.ui.internal.progress.ProgressManager.busyCursorWhile(ProgressManager.java:995)
at org.eclipse.ui.internal.progress.ProgressManager.busyCursorWhile(ProgressManager.java:970)
at org.eclipse.ui.internal.progress.ProgressManager.run(ProgressManager.java:1166)
at org.eclipse.acceleo.module.sample.ui.popupMenus.AcceleoGenerateSampleAction.run(AcceleoGenerateSampleAction.java:91)
at org.eclipse.ui.actions.ActionDelegate.runWithEvent(ActionDelegate.java:70)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:241)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Caused by: java.lang.IllegalArgumentException: Argument cannot be null
at org.eclipse.swt.SWT.error(SWT.java:4263)
at org.eclipse.swt.SWT.error(SWT.java:4168)
at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
at org.eclipse.swt.widgets.Link.addSelectionListener(Link.java:149)
at org.eclipse.acceleo.common.ui.notification.NotificationDialogUtil.notify(NotificationDialogUtil.java:230)
at org.eclipse.acceleo.common.ui.notification.NotificationDialogUtil.notify(NotificationDialogUtil.java:131)
at org.eclipse.acceleo.internal.ide.ui.notifications.AcceleoGenerationListener$1.run(AcceleoGenerationListener.java:79)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
... 42 more
!ENTRY org.eclipse.acceleo.module.sample.ui 4 0 2011-12-03 12:46:54.755
!MESSAGE
!STACK 0
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:421)
Caused by: org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.IllegalArgumentException: Argument cannot be null)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:196)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4683)
at org.eclipse.acceleo.internal.ide.ui.notifications.AcceleoGenerationListener.generationCompleted(AcceleoGenerationListener.java:71)
at org.eclipse.acceleo.engine.service.AcceleoService.finalizeGeneration(AcceleoService.java:1003)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.generate(AbstractAcceleoGenerator.java:198)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.doGenerate(AbstractAcceleoGenerator.java:158)
at org.eclipse.acceleo.module.sample.main.Generate.doGenerate(Generate.java:190)
at org.eclipse.acceleo.module.sample.ui.common.GenerateAll.doGenerate(GenerateAll.java:94)
at org.eclipse.acceleo.module.sample.ui.popupMenus.AcceleoGenerateSampleAction$1.run(AcceleoGenerateSampleAction.java:76)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
Root exception:
More specifically, exception is caused during execution of:
generator.doGenerate(BasicMonitor.toMonitor(monitor));
If I move this project to ACCELEO 3.1 then, no problem is occured.
How to get rid of this exception message (in Acceleo 3.2)? Because, this message terminates monitor and next tasks/activities.
Thanks for any kind of help.
Best Regards,
Atif/
[Updated on: Sat, 03 December 2011 12:23] by Moderator
Re: [ACCELEO] Argument cannot be null [message #760938 is a reply to message #760604] Mon, 05 December 2011 11:25 Go to previous message
This is a known issue that has been fixed for Acceleo 3.2.1 and 3.3.0, you can grab a nightly build if you want containing this fix. The bug will not influence the generation in any way.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau & @acceleo
Google+: stephane.begaudeau & acceleo
Blog: http://stephanebegaudeau.tumblr.com
Acceleo Documentation: http://docs.obeonetwork.com/acceleo
Previous Topic:using acceleo to M2M
Next Topic:[Acceleo] Progress Reporting
Current Time: Sat Jul 19 11:34:53 EDT 2025
Powered by FUDForum. Page generated in 0.03930 seconds
