Home » Newcomers » Newcomers » [Resolved] failed to load shared library(having issues configuring ini for Win7)
[Resolved] failed to load shared library [message #760640] Sat, 03 December 2011 13:55 Go to next message
Hi everyone-
I am trying to set up my machine to run Eclipse and have encountered a lot of errors. After troubleshooting I have now succeeded in getting it the "try" to start but I get shot down now at the following error...
Failed to load the JNI shared library "C:\Program Files (x86)\Java\jre6\bin\client\jvm.dll"
Below is my current ini file
-startup
plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.100.v20110502
-product
org.eclipse.epp.package.java.product
-vm
--launcher.defaultAction
openFile
--launcher.XXMaxPermSize
256M
-showsplash
org.eclipse.platform
256m
openFile
-vmargs
-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx384m
[Updated on: Sat, 03 December 2011 17:56] by Moderator
Re: failed to load shared library [message #760641 is a reply to message #760640] Sat, 03 December 2011 13:59 Go to previous messageGo to next message
and I guess I should have looked a few minutes more before posing this *doh* I was not pointing to the exe- Now I am getting an error but reading through it it is throung out win os 32 and I am running 64 so I am guessing my versions do not match- I will follow up
Edit:
*following up*
The I have verified I am running java for 64bit and I when I downloaded eclipse I picked 64bit... I have no clue what the problem is... I will attach the message thrown...
*following up following up*
I pointed my ini to look in program files not program file x86 and it works now
  • Attachment: eclipse.png
    (Size: 34.59KB, Downloaded 476 times)
Re: failed to load shared library [message #760738 is a reply to message #760641] Sun, 04 December 2011 19:11 Go to previous messageGo to next message
How did you verify that you're launching a 64-bit Java VM?
Re: failed to load shared library [message #762365 is a reply to message #760738] Wed, 07 December 2011 19:05 Go to previous message
i guess i *didn't* i just managed to get it working which is all I care about @ this point lol
Once I am more familiar with the IDE I will refine it to verify that java is 64bit and eclipse is as well
Previous Topic:Minimalist GUI, do I need to add anything to Eclipse IDE?
Next Topic:"build" eclipse
Current Time: Sat Jul 19 08:40:20 EDT 2025
Powered by FUDForum. Page generated in 0.12218 seconds
