Home » Newcomers » Newcomers » Need help with /frameset syntax in INDEX.JSP for reports with parameters.(BIRT viewer /frameset syntax in INDEX.JSP.)
Need help with /frameset syntax in INDEX.JSP for reports with parameters. [message #759849] Wed, 30 November 2011 05:15 Go to next message
I've developed some BIRT reports in eclipse and they all work fine. I wanted to make the reports available to the users via the WebViewerExample web app. I've installed the WebViewerExample under tomcat 6.0.33 successfully. I've also customized the INDEX.JSP that comes with the wiewer to list my reports for selection to the users. The reports that do not have parameters set up are working fine, but the reports that are supposde to show the parm window are not working. I'm getting the following error:
The report file : C:\apache-tomcat-6.0.33\webapps\WebViewerExample/COSTCTR_MATCH_TO_PROCESS_parm_deptmgr.rptdesign does not exist or contains errors.[/color]
The code in the INDEX.JSP looks like:
<p>
<a
href="<%= request.getContextPath( ) + "/frameset?__report=COSTCTR_MATCH_TO_PROCESS_parm_deptmgr.rptdesign&__DEPTMGR=blank" %>">IS
Department Mgr. Report - Detail of Appian Process Hours Spent,
Select by Department Mgr.</a></p>
The above report is using one parm 'DEPTMGR'. I also need help with the syntax for a report with multiple parms, what is the syntax for the /frameset to enable the parm window to show. the code below is for a report with multiple parms:
<p>
<a
href="<%= request.getContextPath( ) + "/frameset?__report=COSTCTR_MATCH_TO_PROCESS_parm_ProcID_Prod_on_time.rptdesign" %>">IS
Select by ProcID and Process On Time</a></p>
your assistance would be appreciated.
Re: Need help with /frameset syntax in INDEX.JSP for reports with parameters. [message #759952 is a reply to message #759849] Wed, 30 November 2011 11:51 Go to previous messageGo to next message
> [snip]
Ask this in the Eclipse BIRT forum?
Re: Need help with /frameset syntax in INDEX.JSP for reports with parameters. [message #760155 is a reply to message #759952] Thu, 01 December 2011 08:48 Go to previous message
Thank you Russell. Just did that....
Previous Topic:Creating Linux executable in Eclipse
Next Topic:cant build or run .asm file
Current Time: Sun Jul 20 02:39:05 EDT 2025
Powered by FUDForum. Page generated in 0.09376 seconds
