Home » Archived » EGL Development Tools » Possible problem with basic handlers
Possible problem with basic handlers [message #759081] Sat, 26 November 2011 00:41 Go to next message
I encountered an issue with a large-ish application that I think I have boiled down into a simple example...
First, a working example. A simple basic handler and a RUI handler:
package com.dandarnell.life.client;
handler TestBasic
	private state int;
	function setState(state int in)
		this.state = state;
	end
	function getState() returns(int)
		return(state);
	end
end
import org.eclipse.edt.rui.widgets.*;
handler TestRUI type RUIhandler{initialUI =[ui], onConstructionFunction = start, cssFile = "css/Test2.css"}
    ui GridLayout{columns = 3, rows = 4, cellPadding = 4, children =[l]};
	l TextLabel { text = "state=nil", layoutData = new GridLayoutData {row=1, column=1} };
	testBasic TestBasic[] = new TestBasic[2];
    function start()
    	x int = testBasic[1].getState();   // <--- this works
    	l.text = x;
    end
end
Now, the non-working example. No change to the basic handler. The difference in the RUI handler is a multi-dimensional array.
	testBasic TestBasic[][] = new TestBasic[2][2];   //<------------------
    function start()
    	x int = testBasic[1][1].getState();              //<--doesn't work
    	l.text = x;
    end
end
Here's the runtime error:
Could not render UI
Object doesn't support this property or method
[CRRUI2094E] Here are the EGL function calls leading to this error:
com/dandarnell/life/client/TestRUI.egl() at line 13
TestRUI.<init>() [native JavaScript]
Line 13 is...
Interestingly, I have seen cases where this code is flagged as in-error in the editor. Clicking on the "X" shows an internal runtime exception. In other cases, no error in indicated in the editor but the runtime error occurs.
Also, it matters NOT that the code is in the onConstruction function. Anywhere I use similar code I get the error.
Am I doing something wrong or is this a bug?
--Dan
Re: Possible problem with basic handlers [message #759474 is a reply to message #759081] Mon, 28 November 2011 14:06 Go to previous messageGo to next message
I moved away from using basic handlers and defined my data in a record and used a library for functions to operate on that data.
I encountered errors with this implementation as well. Again, only with a multi-dimensional array. Bug?
--Dan
Re: Possible problem with basic handlers [message #759782 is a reply to message #759474] Tue, 29 November 2011 21:22 Go to previous messageGo to next message
Dan,
This sounds like a bug, go ahead and open a new defect against the JavaScript component - https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EDT.
-Brian
Re: Possible problem with basic handlers [message #760297 is a reply to message #759782] Thu, 01 December 2011 14:43 Go to previous message
Created bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=365356
--Dan
Previous Topic:EDT SQLDataSource init error - REST webservices - running on tomcat
Next Topic:jt400.jar not working in deployed application
Current Time: Sat Jul 19 14:28:59 EDT 2025
Powered by FUDForum. Page generated in 0.04467 seconds
