Home » Modeling » TMF (Xtext) » Handwritten formatter?
Handwritten formatter? [message #759440] Mon, 28 November 2011 11:57 Go to next message
I have a couple of requirements in the formatter for Geppetto that makes
me think I am best served by writing a formatter from scratch.
I want to be able to modify the formatting rules via preferences, and
the formatter needs to make decisions based on the length of lists, and
in some cases, the actual values of things.
Has someone implemented something similar somewhere that I could take a
peek at?
Any other general advice? The IFormatter interface looks suspiciously
simple :)
- henrik
Re: Handwritten formatter? [message #759637 is a reply to message #759440] Tue, 29 November 2011 07:27 Go to previous messageGo to next message
I looked at code, and googled for info on the topic.
This message thread:
http://dev.eclipse.org/mhonarc/lists/xtext-dev/msg00888.html and the
issue that was logged as a result of that discussion:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=313289
The thread talks about the ParseTreeConstructor, and the complication
that when it calls the formatter, there is no node model. (The issue
also mentions this, and some other cases where there is no associated
node model).
I am wondering what you think regarding the evolution of the formatter.
Is it likely to stay more or less as it is, with the addition of also
passing the current semantic object through the pipeline, or do you see
it radically changing?
- henrik
On 2011-28-11 17:57, Henrik Lindberg wrote:
> peek at?
> simple :)
> Regards
> - henrik
Re: Handwritten formatter? [message #760088 is a reply to message #759637] Thu, 01 December 2011 04:42 Go to previous message
Hi Henrik,
I'm hoping to reimplement the formatter soon, but so far other things
had a higher priority. It's bothering us, too, the that old formatter
isn't powerful enough to handle the Xtend language.
A new formatter would have access to the node model, the semantic model
and would not be restricted to the old formatters "rule engine".
Furthermore, it would work with the new serializer, since the
ParseTreeConstructor is about to be phased out.
regards,
Moritz
> node model).
> - henrik
>> Hi,
>> peek at?
>> simple :)
>> Regards
>> - henrik
Previous Topic:Grammar question
Next Topic:[xtext 2.0] protected region support?
Current Time: Sun Jul 20 18:09:35 EDT 2025
Powered by FUDForum. Page generated in 0.07023 seconds
