Home » Modeling » EMF » Indirectly referenced Generator Model required although unnecessary
Indirectly referenced Generator Model required although unnecessary [message #758562] |
Wed, 23 November 2011 11:53  |
suppose I have 3 Ecore meta-models A, B and C,
with B referencing model elements from A
and with C referencing elements from B (i.e. A <- B <- C).
When I create the genmodel for B, I naturally have to supply A's genmodel
("Referenced Generator Models").
However when creating the genmodel for C, I not only have to select B's genmodel
but also A's, although C does not use any elements from it.
After code generation I can safely remove C's dependency to A from MANIFEST.MF
without getting compiler/runtime errors.
So my question is, why does the Generator require this indirect
(and in my eyes, unnecessary) dependency?
The reason I ask is that in the target environment A will not be accessible from
"outside" (i.e. from C), but only from B which can be seen as an "export interface"
for A, providing access to some public features.
The genmodel for A would thus not be available to the "outside" aswell.
Tim
Re: Indirectly referenced Generator Model required although unnecessary [message #758565 is a reply to message #758562] |
Wed, 23 November 2011 12:24   |
Tim,
Comments below.
On 23/11/2011 5:53 PM, Tim Schaefer wrote:
> B's genmodel
What's the nature of the references you mentioned?
> MANIFEST.MF
Does the B export its dependencies on A? Often people don't like to do
that and change it...
> accessible from
> "export interface"
Can you elaborate on that?
In any case, you can modify the manifest and it won't be changed
afterward...
> Regards,
> Tim
Re: Indirectly referenced Generator Model required although unnecessary [message #758721 is a reply to message #758581] |
Thu, 24 November 2011 06:48   |
Tim,
Comments below.
On 23/11/2011 7:20 PM, Tim Schaefer wrote:
> Hi Ed,
> thanks for your fast reply.
> EReferences with EType set to an EClass of the referenced model.
So interfaces will definitely expose the types of the accessor methods,
right?
> They delegate feature-queries (derived estructuralfeatures) to the
> referenced EObject.
So the implementation classes make use of the accessor methods...
> No, it doesn't export them.
In my experience, the compiler will complain about classes indirectly
referenced by a used class needing to be be on the classpath...
>> afterward...
> Sure, but it might be possible that A's genmodel is not available in
> the future
> (e.g. not visible for C) and then I could not reload C's genmodel.
It seems to me that B has methods whose types reveal A's generated
interfaces so any changes to A will be apparent...
> Does the Generator Model require the indirectly referenced genmodel or
> is this just
> a requirement of the Model Importer wizard?
It does currently require them. You could try deleting the
usedGenPackage and see how unhappy that makes the generator...
> If the latter is the case, maybe I could write my own model importer
> and override this behavior?
Anyone using your model will necessarily be able to traverse any
dependencies and will see the closure of all models. They will see A
whether you like it or not, and can create dependencies on it such that
if you change it, they will be broken...
> Regards,
> Tim
Re: Indirectly referenced Generator Model required although unnecessary [message #758750 is a reply to message #758740] |
Thu, 24 November 2011 08:31   |
Tim,
Comments below.
On 24/11/2011 1:53 PM, Tim Schaefer wrote:
> Hi Ed,
> the three models are really decoupled in a way that C does not see any
> types of A.
Hmmm.
> It just accesses attributes of Bs objects and B internally delegates
> the requests.
Before you mentioned references in B's classes referring to classes in
A. I don't see how that's manifested in the generated API in a way
that hides A.
> Anyway, I think you're right, A can not be hidden from the overall
> classpath,
No, it clearly needs to be there...
> so my consideration about A being unaccessible makes no sense.
In general it might be a hidden implementation detail (though I don't
see how that's possible with references to classes in A) but, as I said,
the GenModel and Ecore models will definitely reveal the existence of A
no matter what you do...
> Thanks for your time.
> Regards,
> Tim
Re: Indirectly referenced Generator Model required although unnecessary [message #758804 is a reply to message #758750] |
Thu, 24 November 2011 10:40  |
Hi Ed,
sorry, the term "internal" was misleading. B's classes reference classes from A,
so they have getter/setter for these. But the classes from C don't use these getters/setters,
they only access B's attributes.
If I intentionally remove C's dependency to A, classes in C can see B's accessors
for the elements of A, but they are not "usable" for them since the types are unknown to them.
Anyway, you are right, all plugins are needed in the classpath so it doesn't really
matter whether C can see A.
Tim
Current Time: Sun Jul 20 16:03:09 EDT 2025
Powered by FUDForum. Page generated in 0.05595 seconds
