Home » Eclipse Projects » Rich Client Platform (RCP) » Enable "Always run in background" for Jobs as Default
Enable "Always run in background" for Jobs as Default [message #758425] Wed, 23 November 2011 04:12 Go to next message
I would like to enable the "General" option "Always run in background" for jobs as the default for a fresh installed RCP application so that the user don't have to select this option in the preferences. How can i enable this for my application?
Any help is appreciated!
Re: Enable "Always run in background" for Jobs as Default [message #758715 is a reply to message #758425] Thu, 24 November 2011 06:01 Go to previous messageGo to next message
I think putting
org.eclipse.ui/RUN_IN_BACKGROUND=true
in the plugin_customization.ini should work
Re: Enable "Always run in background" for Jobs as Default [message #758978 is a reply to message #758715] Fri, 25 November 2011 08:11 Go to previous messageGo to next message
Thanks for the answer. I've enabled the plugin_customization.ini in my product but this file seems to be ignored. Any idea what could be wrong in my product configuration?
Re: Enable "Always run in background" for Jobs as Default [message #758983 is a reply to message #758978] Fri, 25 November 2011 08:23 Go to previous messageGo to next message
Have you:
a) added it to your build.properties
b) added a property
<property
name="preferenceCustomization"
value="plugin_customization.ini"/>
to your org.eclipse.core.runtime.products extension point?
HTH & Greetings from Bremen,
Daniel Krügler
Re: Enable &amp;quot;Always run in background&amp;quot; for Jobs as Default [message #759001 is a reply to message #758983] Fri, 25 November 2011 09:45 Go to previous messageGo to next message
Hello Daniel,
yes everything seems to be configured fine.
Re: Enable &amp;amp;quot;Always run in background&amp;amp;quot; for Jobs as Default [message #759271 is a reply to message #759001] Mon, 28 November 2011 03:38 Go to previous messageGo to next message
On 2011-11-25 15:45, Marcel wrote:
> Hello Daniel,
Just to be sure: Is your plugin_customization.ini working but only the
RUN_IN_BACKGROUND is not recognized or is the plugin_customization.ini
not working at all?
Btw.: It seem that the required key should be:
org.eclipse.ui.workbench/RUN_IN_BACKGROUND
not
as indicated by Greg.
Daniel Krügler
Re: Enable &amp;amp;quot;Always run in background&amp;amp;quot; for Jobs as Default [message #759277 is a reply to message #759271] Mon, 28 November 2011 03:54 Go to previous messageGo to next message
Hello Daniel,
thanks for the help. It seems that the plugin_customization.ini is not working at all.
Re: Enable &amp;amp;amp;quot;Always run in background&amp;amp;amp;quot; for Jobs as Default [message #759283 is a reply to message #759277] Mon, 28 November 2011 04:13 Go to previous messageGo to next message
On 2011-11-28 09:54, Marcel wrote:
> Hello Daniel,
> working at all.
A typical reason for this problem could be that your launch
configuration does not clear the workspace, therefore it will still use
the previous settings. Ensure that on tab "Main" you have selected
Clear
and marked "workspace" as well. In addition select tab "Configuration"
and ensure that
Clear the configuration area before launching
is selected as well.
Daniel Krügler
Re: Enable &amp;amp;amp;quot;Always run in background&amp;amp;amp;quot; for Jobs as Default [message #759388 is a reply to message #759283] Mon, 28 November 2011 09:27 Go to previous messageGo to next message
Hello Daniel,
thank you very much for your help.
After a few new tries i found the solution.
My mistake was that i've forgotten to set the value from your new suggestion.
org.eclipse.ui.workbench/RUN_IN_BACKGROUND (wrong!)
instead:
org.eclipse.ui.workbench/RUN_IN_BACKGROUND=true (correct!)
(arrrggg...... Mad )
Finally it works!
Re: Enable &amp;amp;amp;quot;Always run in background&amp;amp;amp;quot; for Jobs as Default [message #774736 is a reply to message #759388] Wed, 04 January 2012 08:58 Go to previous message
It is an old topic, but it may be worth adding this note for those wanting to avoid the .ini file.
Add the following line to ApplicationWorkbenchWindowAdvisor.preWindowOpen
WorkbenchPlugin.getDefault().getPreferenceStore().setValue("RUN_IN_BACKGROUND", true);
Previous Topic:Dynamically create eclipse main menu item or global toolbar item
Next Topic:TreeViewer losing selection on collapse
Current Time: Sun Jul 20 11:41:48 EDT 2025
Powered by FUDForum. Page generated in 0.08066 seconds
