Home » Eclipse Projects » EGit / JGit » Git Plugin in RCP - Wizard Error
Git Plugin in RCP - Wizard Error [message #758292] Tue, 22 November 2011 10:15 Go to next message
I would like to use the EGit plugin in my RCP application. Everything works fine so far.
Only one error remains. If i open the Wizard "Git Repository" from File->New->Git an error is thrown:
"the selected wizard could not be started.
Plug-in "org.eclipse.egit.ui" was unable to instantiate class "org.eclipse.egit.ui.internal.repository.NewRepositoryWizard".
Does anyone know why this error is thrown?
Any help is appreciated!
Re: Git Plugin in RCP - Wizard Error [message #758330 is a reply to message #758292] Tue, 22 November 2011 13:48 Go to previous messageGo to next message
I believe this has been fixed in master and currently in the 1.2.0 nightlies.
http://egit.eclipse.org/r/#change,4266
Re: Git Plugin in RCP - Wizard Error [message #758422 is a reply to message #758330] Wed, 23 November 2011 04:03 Go to previous messageGo to next message
O.K. Thanks for the fast reply and the information!
Re: Git Plugin in RCP - Wizard Error [message #759785 is a reply to message #758292] Tue, 29 November 2011 23:26 Go to previous messageGo to next message
I know this is a bit of a NOOB question but how does one get ahold of the fix?
Re: Git Plugin in RCP - Wizard Error [message #759889 is a reply to message #758330] Wed, 30 November 2011 08:41 Go to previous messageGo to next message
Nevermind... as with all NOOB questions the answer is use a search engine Smile
Re: Git Plugin in RCP - Wizard Error [message #759998 is a reply to message #759889] Wed, 30 November 2011 15:44 Go to previous message
If you want the binaries install from http://download.eclipse.org/egit/updates-nightly
If you want sources checkout the EGit contributor guide http://wiki.eclipse.org/EGit/Contributor_Guide
Previous Topic:[jgit] Find Commits for Notes
Next Topic:branch deletion disabled?
Current Time: Sat Jul 19 21:55:39 EDT 2025
Powered by FUDForum. Page generated in 0.08461 seconds
