Home » Modeling » TMF (Xtext) » [Xtend2] Problem Creating JvmTypeReference to Existing Classes
[Xtend2] Problem Creating JvmTypeReference to Existing Classes [message #758393] Wed, 23 November 2011 00:32 Go to next message
Hey,
I'm trying to have all the classes I generate implement a specific interface. For simplicity let me demonstrate what I want to with the "Five simple steps to your JVM language" Tutorial as a basis.
I want all my classes to implement one interface, IEntity (just a dummy for demonstration):
package org.eclipse.xtext.example.domainmodel.runtime
public interface IEntity {}
I'm trying to do this by adding the interface to the list of superclasses of all the classes I generate like so (in DomainmodelJvmModelInferrer.xtend):
import org.eclipse.xtext.example.domainmodel.runtime.IEntity
def dispatch infer(Entity e, IAcceptor<JvmDeclaredType> acceptor, boolean prelinkingPhase) {
		acceptor.accept(
			e.toClass( e.fullyQualifiedName ) [
				// Always returns null :(
				superTypes += e.newTypeRef(typeof(IEntity))
Which always throws an AssertionError Sad
What am I doing wrong? Is ``newTypeRef()'' the wrong function to use?
Re: [Xtend2] Problem Creating JvmTypeReference to Existing Classes [message #758407 is a reply to message #758393] Wed, 23 November 2011 02:23 Go to previous messageGo to next message
Are you adding the interface IEntity to the classpath of the project? You have to add this interface (or any other class) to both the plug-in project and the model project.
Re: [Xtend2] Problem Creating JvmTypeReference to Existing Classes [message #758610 is a reply to message #758407] Wed, 23 November 2011 16:08 Go to previous messageGo to next message
Currently IEntity is in the org.eclipse.xtext.example.domainmodel.runtime package inside the domainmodel plugin. The manifest of domainmodel is set to export org.eclipse.xtext.example.domainmodel.runtime:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Xtext Domainmodel Example
Bundle-Vendor: Eclipse Modeling Project
Bundle-Version: 2.2.0.qualifier
Bundle-SymbolicName: org.eclipse.xtext.example.domainmodel; singleton:=true
Export-Package: org.eclipse.xtext.example.domainmodel,
 org.eclipse.xtext.example.domainmodel.runtime,
The domainmodel.ui plugin requires the domainmodel plugin:
Bundle-Name: Xtext Domainmodel Example UI
Bundle-SymbolicName: org.eclipse.xtext.example.domainmodel.ui; singleton:=true
Bundle-ActivationPolicy: lazy
Require-Bundle: org.eclipse.xtext.example.domainmodel;bundle-version="2.0.0",
Is that what you mean by adding it to the classpath?
Re: [Xtend2] Problem Creating JvmTypeReference to Existing Classes [message #758612 is a reply to message #758610] Wed, 23 November 2011 16:32 Go to previous messageGo to next message
as you have to add xbase.lib to the classpath of the project the model file is contained you have to add the plugin that contains your IEntity as well
~Christian
Re: [Xtend2] Problem Creating JvmTypeReference to Existing Classes [message #758620 is a reply to message #758612] Wed, 23 November 2011 17:47 Go to previous messageGo to next message
Hi Christian,
IEntity.java is already in the same plugin as the model file (Domainmodel.xtext)
~Boris
Re: [Xtend2] Problem Creating JvmTypeReference to Existing Classes [message #758650 is a reply to message #758620] Thu, 24 November 2011 01:11 Go to previous messageGo to next message
I am talking about the model (blablabla.dmodel) and not the grammar
[Updated on: Thu, 24 November 2011 01:17] by Moderator
Re: [Xtend2] Problem Creating JvmTypeReference to Existing Classes [message #758871 is a reply to message #758650] Thu, 24 November 2011 16:10 Go to previous message
Wow, that was blindingly obvious in hindsight. Thank you so much for your patience and promptness.
Vielen Dank,
Boris
Previous Topic:Use/migrate grammar of ANTLR3 in xtext, is possible?
Next Topic:[Xtext 2.1] property databinding in own dsl
Current Time: Sun Jul 20 16:36:28 EDT 2025
Powered by FUDForum. Page generated in 0.07781 seconds
