Home » Archived » BIRT » Embedding a datasource in the rptdesign file?
Embedding a datasource in the rptdesign file? [message #757719] Mon, 21 November 2011 05:57 Go to next message
I have a rptdesign file with some xml and csv datasources that I store to disk after the content has been previewed by a user.
I need to read this file in another report application with the same datasources and values. It could be nice if it was possible to read the rptdesign file and the datasources were embedded in the file. Is this possible or must datasources always be specified from an external resource?
Re: Embedding a datasource in the rptdesign file? [message #758098 is a reply to message #757719] Mon, 21 November 2011 16:16 Go to previous messageGo to next message
Are you writing out a rptdocument? It has the data in it. You could
use a data extraction task in the report engine api to extracts data
from report items like charts and tables.
Jason
Re: Embedding a datasource in the rptdesign file? [message #758169 is a reply to message #758098] Tue, 22 November 2011 03:48 Go to previous messageGo to next message
I have changed my approach a bit. I first read the chart stored in a .chart file which has a predefined datasource/dataset (primary used to be able to setup colors and other ui styles).
At runtime I populate the dataset using:
  public void setValues(SeriesDefinition axis, List<Float> values) {
    Double[] arr = new Double[values.size()];
    for (int i = 0; i < arr.length; i++) {
      Float val = values.get(i);
      if (val != null) {
        arr[i] = new Double(val);
    NumberDataSet seriesValues = NumberDataSetImpl.create(arr);
    axis.getSeries().get(0).setDataSet(seriesValues);
Then the chart is previewed/rendered using swing. I then serialize the chart. But when working with a .chart file I don't have a way to generate it to a rptdocument - unless I embed it inside a .rptdesign file first.
Re: Embedding a datasource in the rptdesign file? [message #758310 is a reply to message #758169] Tue, 22 November 2011 12:04 Go to previous message
If you do embed the chart you can always use the data extraction task to
get the chart data.
Jason
> if (val != null) {
> file first.
Previous Topic:How to show total of stacked bars
Next Topic:Dynamic parameter properties
Current Time: Sat Jul 19 06:20:58 EDT 2025
Powered by FUDForum. Page generated in 0.07579 seconds
