Home » Modeling » EMF » Static package registration not populating same registry accessed by EMF deserialization code(When calling an EMF implementation from an EJB which is in turn called by a WAR, the registry does not appear populated)
Static package registration not populating same registry accessed by EMF deserialization code [message #757539] Fri, 18 November 2011 14:54 Go to next message
I am using MDHT, which is based on EMF, in my project. I am calling MDHT from one of my libraries which uses MDHT/EMF to parse an XML file and map it to a POJO. That library is invoked from an EJB. This has worked wonderfully for over a year.
Recently, my team added support for a use case where a user would upload a CCD from a WAR. The WAR then calls the EJB to process that file. This fails.
What seems to be happening is that the initial population of the EPackage.Registry goes OK, but then when the file is deserialized in EMF the Registry doesn't appear to have the packages that were loaded.
Looking at the debugger it appears that the EJB and WAR are using the same classloader when the registry is populated and when it is read. There should not be any threading issues in play, the WAR and EJB should run in the same thread. Even if they don't the EJB calls to my library and MDHT/EMF will happen in the same thread.
I'm in a little over my head. Please let me know what additional information to provide to describe this isssue.
What possible causes are there for this issue?
Any fixes or workarounds?
This has been discussed on the MDHT users list - https: www.projects.openhealthtools.org/sf/go/projects.mdht/discussion.forum1136.topc11587
Re: Static package registration not populating same registry accessed by EMF deserialization code [message #757977 is a reply to message #757539] Sat, 19 November 2011 03:35 Go to previous messageGo to next message
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
Jon,<br>
<br>
Comments below.<br>
<br>
On 18/11/2011 8:54 PM, Jon.B wrote:
<blockquote cite="mid:ja6d4t$cih$1@news.eclipse.org" type="cite">I
<br>
<br>
<br>
<br>
loaded.
<br>
</blockquote>
The package registry in stand alone mode is class loader scoped.<br>
<br>
read.</blockquote>
There wouldn't be a problem in that case...<br>
<br>
<br>
<br>
<br>
What possible causes are there for this issue? </blockquote>
It must be an issue of class loaders...<br>
<blockquote cite="mid:ja6d4t$cih$1@news.eclipse.org" type="cite">Any
<br>
</blockquote>
You can see how the registry is populated in EPackageRegistryImpl<br>
<blockquote>  public static EPackage.Registry createGlobalRegistry()<br>
  {<br>
    try<br>
    {<br>
      String className =
System.getProperty("org.eclipse.emf.ecore.EPackage.Registry.INSTANCE");<br>
</blockquote>
So one brute force solution is to specify this property with the
value org.eclipse.emf.ecore.impl.EPackageRegistryImpl<br>
<br>
<a class="moz-txt-link-abbreviated" href="http://www.projects.openhealthtools.org/sf/go/projects.mdht/discussion.forum1136.topc11587">www.projects.openhealthtools.org/sf/go/projects.mdht/discussion.forum1136.topc11587</a><br>
</blockquote>
</body>
</html>
Re: Static package registration not populating same registry accessed by EMF deserialization code [message #757978 is a reply to message #757539] Sat, 19 November 2011 05:01 Go to previous messageGo to next message
On 18/11/2011 19:54, Jon.B wrote:
> What possible causes are there for this issue? Any fixes or workarounds?
It is highly likely that you have two differently managed registries.
I find that when something impossible happens with models, there is no
substitute for checking out emf.ecore or emf.ecore.xmi as projects and
inserting a few println's printing out activity and object hashcodes.
Find out who's constructing registries. Find out who's gaining access to
the contents.
Instrumenting ResourceSetImpl.getResource is also helpful.
Ed Willink
Re: Static package registration not populating same registry accessed by EMF deserialization code [message #757979 is a reply to message #757978] Sat, 19 November 2011 11:16 Go to previous messageGo to next message
Ed,
It's highly likely to be related to EPackageRegistryImpl.Delegator doing
funky things in a context that has a funky class loader scheme as web
containers do...
On 19/11/2011 11:01 AM, Ed Willink wrote:
> Hi
> to the contents.
> Regards
> Ed Willink
Re: Static package registration not populating same registry accessed by EMF deserialization code [message #758042 is a reply to message #757979] Mon, 21 November 2011 14:55 Go to previous messageGo to next message
So one brute force solution is to specify this property with the value org.eclipse.emf.ecore.impl.EPackageRegistryImpl
Bah I misread the statement at first.
Thank you for the advice. I will try that and report back!
[Updated on: Mon, 21 November 2011 15:01] by Moderator
Re: Static package registration not populating same registry accessed by EMF deserialization code [message #758092 is a reply to message #758042] Mon, 21 November 2011 16:12 Go to previous messageGo to next message
Hot damn! Setting that property seems to fix the problem.
So what is this actually doing? Why does this work?
Re: Static package registration not populating same registry accessed by EMF deserialization code [message #758108 is a reply to message #758092] Mon, 21 November 2011 16:40 Go to previous messageGo to next message
Jon,
The default stand alone instance is EPackageRegistryImpl.Delegator which
is class loader scoped; that seems to be causing you a problem (but
you've not explained enough detail for me to know why).
Re: Static package registration not populating same registry accessed by EMF deserialization code [message #758115 is a reply to message #758108] Mon, 21 November 2011 17:20 Go to previous messageGo to next message
What details can I look for or provide to explain the behaviour?
Re: Static package registration not populating same registry accessed by EMF deserialization code [message #758147 is a reply to message #758115] Tue, 22 November 2011 01:29 Go to previous message
Jon,
Can you reproduce the problem under debug control?
Here's my understanding of how web containers use class loaders. The
container itself has a class loader and it creates one for each thread
or each thing that runs in the container. That one has the container's
class loader as its parent. When the package is initialized,
Thread.getContextClassLoader determines which of a chain of registries
(corresponding to the chain of class loaders) will contain the
registration. When you do a lookup, the same process is used to find
it. So if the package is registered with one context and then lookup
happens with a different context that's not below the registered one
(below as defined by the opposite of ClassLoader.getParent), it won't be
visible. This allows different containers to avoid colliding their
registrations and even to register different versions of the same package.
As another nasty wrinkle, some web containers (e.g., WebSphere) use EMF
themselves and you might end up with their version of EMF, not your
own. You need to set some property for PARENT_LAST or something like
that so that the parent is the last place that's used to resolve classes
you need to load so you can ensure that your version of EMF is used.
As Ed suggested, do a Thread.dumpStack in your package init and see
where it's being registered. Registering early in a know context would
be a better workaround.
Previous Topic:[CDO] Import/Export for model migration?
Next Topic:[Query2] Execute queries on large model
Current Time: Sun Jul 20 14:27:26 EDT 2025
Powered by FUDForum. Page generated in 0.04413 seconds
